MYM MACHINE MAKES A ALWFUL SOUND WHEN SPINNING
  • David Ellis Rhea Dec 26, 2016
    Hi DARYL SCHIFF, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please share the approximate year, the model, and the make of your washer.
When spinning washing machine jumps a bit and makes a rattling noise as if something is loose in machine.
may need to balance machine on floor and or check the shocks, the balance springs, the counter weights or suspension rods, etc and or the motor coupler
Jun 08, 2015 | Washing Machines
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
My frigidaire LTF6700FSO will not spin
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
No spin... makes a clacking clattery noise
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Samsung WF337AA Front Load Washer
Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
