Question about Jenn-Air Kitchen Ranges
Jenn air jds9860bds dual fuel range: Oven Light stays on, convect fan won't turn on, clean shows Close Door-door is closed.
I think I need a new light switch at the do I access the switch and how do I order the switch? Also how do I enter diagnostic mode and get code info, etc.
SOURCE: oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Posted on Jan 18, 2008
SOURCE: Jenn-Air Glass Door - How to Clean
Sounds familiar. I saw this thread this afternoon while trying to clean my own oven window. My sense is it is definitely a design flaw. It's just too easy to drip something down the top door vents onto the inside of the multiple glass panes.
Here's what I did. I removed the door, following the manual instructions. Open the door to 1/4 and lift it up. Then I put it down on a soft surface and started removing screws until it came apart. It wasn't too complicated though it took some time. Be sure to keep track of your screws as you do this as there are a few different kinds.
Posted on Aug 12, 2008
  • 3361 Answers
SOURCE: Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Posted on Mar 08, 2009
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
  • 6784 Answers
SOURCE: microwave not working
HI, this is a faulty control panel. replace asap if possible.
Posted on May 29, 2009
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Door sags open when hot.
i just had this problem with a jenn air range i was repairing, installed new hinges door closed fine, heated oven hit 200 degrees and light came on (door opened slightly) as per techline I shimmed the hinge reciever to make a bit tighter. sure enough!!! been 3 weeks she hasnt called back yet (and trust me if it didnt work she would!.. call the tech back and have him call the tech line while in home
Mar 13, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
JDS9865BDP door won't close
Could you please describe the problem you are having a little better?
Nov 27, 2012 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
I need direction on how to start the clean cycle on my jenn air
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
Thanks for using Fix Ya, Please take the time to rate this solution.
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Jenn-Air Gas-Electric Grill Ranfe with Convection Oven M# SVD48600
if possible, squat down in front of the range and put your ear as close to the bottom of the control panel/top of the door when you close it. there is a small motor that pulls the door in when you use the self-cleaning function. perhaps that motor is running all the time? its quite, more of a humm. this could explain why its locking itself. other than that, my convection oven JennAir has a small fan in the back that runs when the oven is on, regular or convections mode. you can see this fan squirel cage in the back wall of the oven. if you were to pull the range out, you will notice (atleast on mine) that there is another much smaller fan on the backside of the range behind the removable metal panel. what the smaller fan is for, i have no idea. so there are two fans, plus if you have the down draft feature, thats 3 total. hope this helps somehow.
Jun 21, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Kenmore oven door 790. won't close all the way
Jan 11, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Jenn-Air- model # SVE47600B
I was cleaning the oven and leaning on the oven door and now when I close the door it is hard to close
Dec 20, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
44 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
