Question about Mtd Snowthrower 208cc 26"
Have a 9.5h.p.tecumseh eng. on a mtd snowthrower w/elect. chute. when I push the toggle switch, voltage @ the chute wires drops to 5 v. everything else works (light,heat grips).Need a wiring diagram.
Is the voltage coming out a.c.? yellow wire has a diode(?)and goes to the light. red goes to heated grips & toggle switch for elect.chute.
SOURCE: can you point me to the wiring diagram for the above mower
The flywheel black (negative) and red (positive) wires are the magneto output. Red goes to ignition to charge the battery, and also burn the headlights -- so the red will go to the headlight switch as well, maybe through the ignition.
There should be an in-line fuse on the charging/headlight wire coming from the magneto.
There should be a safety switch under the seat which energizes the fuel cutoff solenoid on the bottom of the carburetor.
There are also interlock switches on blade engage mechanism, and the brake pedal, These prevent engine from starting if brake is not applied or if blades are engaged -- these would control current to the ignition module.
This is not complete, but it'll give you some clues -- good luck -- it's a ton of work.
Posted on May 08, 2009
SOURCE: NEED WIRING DIAGRAM FOR MTD 14.5 HP OHV I/C RIDING MOWER
try going to www.tulsaenginewarehouse.com/drawings/allwiring.pdf
Posted on Aug 29, 2009
backwoodsctr
  • 169 Answers
SOURCE: wiring missing from harness to coil to card
here is a picture from the breakdown of a 15.5 hp briggs engine hope this helps e8059e1.jpg
Posted on Nov 21, 2009
SOURCE: MTD RIDE ON LAWN MOWER SOLENOID
CHANGE DRIVE BELTS
Posted on Nov 09, 2010
BAMOUT
  • 2478 Answers
SOURCE: mtd riding lawn mower with B & S engine i need diagram of wiring harnes conections etc.
Most owner's manual have a wiring in them. I'll try to send you a my picture. See you later.
Posted on Dec 21, 2011
Where do I get voltage for my chute motor on 10.5 hp tecumseh snowblower?
Measure the voltage at the wires going to the motor.
Aug 27, 2016 | Garden
Tecumseh troubleshooting
Check the cutout switches - most likely either a wire is broken or one of the guards or dead mans handle is not fully operating.
Jul 31, 2014 | Mtd 22" Yard Machine Push Mower
Toro snowthrower coil condensor points
If you have changed sparkplug and coil and cleaned flywheel, you probably have a kill wire problem. Disconnect kill wire from coil and try again.
Apr 04, 2014 | Tecumseh Enduro Horizontal Engine 5 HP...
No spark on my MTD Snowblower
ake sure your Kill wire that is hooked to your on/off linkage did'nt come off and is permanately grounded, or if it has a key switch ,make sure that it is not faulty, all else fails you are probably looking at a coil being bad. once you get the shroud off unhook the small wire coming from the coil and then roll over eng and see if there is spark then, if not it is bad coil.
Dec 04, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
For mtd 3hp 2cycle motor only stays running when pushing prime repeatedly on full chock 5 sec
This is usually a symptom of blocked or partially obstructed metering passages in the carburetor. Carburetor should be removed and metering passages cleaned to restore fuel flow through the carburetor.
Feb 12, 2011 | Tecumseh Snowblower Snow Blower Starter...
5 hp tecumseh snow king engine on a murray snowthrower. How far should I unscrew the float screw?
Turn it in all the way gently until it stops then turn out 11/4 turns out.Then tou can fine tune from there.
Dec 15, 2010 | Mtd Garden
How do I replace the starter cord handle on my Tecumseh engine model HMSK90 (snowthrower). The product category selection SUCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
REMOVE THE STARTER..........REWIND THE SPRING/PULLEY BY HAND AND USE A NAIL OR SOMTHING TO KEEP IT FROM UNWINDING.......NEXT INSTALL THE NEW ROPE WHALA JUST LIKE NEW! HOPE THIS HELP
Nov 19, 2009 | Mtd Garden
Mtd Snowthrower 208cc 26" Logo
41 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
