Question about Garden
Jim, Replaced lines,filter,bypassed shutoff solenoid.unsure seat referring to? needle seat threads in. Tested blowing through line with needle open/closed, acts normal. Starts runs 5min dies.
  • 22 Answers
Try running with cap loose if possible. If tank can't vent will create vacuum in tank and "run out of gas". If keeps running replace tank vent, sometimes part of cap.
Posted on Dec 28, 2016
H26 Deutscher with Honda motor starts ok but will only run for short time and cuts out and will not restart until cooled down , can you help thank you
You most likely have a clog in the fuel delivery some where. If the carburetor has a bowel I would suspect the float, it's associated needle and seat, or the fuel line ax nd shutoff. Some engines have a screen filter o. Top of the shutoff. If so equipped which can be an issue. Finally, check to be sure the tank is venting properly. The gas cap vent can become fouled with many different items. Carburetor spray cleaner is best to blow out the passages in the carb body.
Md
Sep 24, 2017 | Honda Cars & Trucks
Generac 15000 4582 won't start - seems to be flooded - blowing fuel out of exhaust - carb solenoid checks out but fuel flows into carb even when off
Carb. Sol. Can work electrically but the seat may not be sealing. Would remove and clean. Also place shutoff valve in fuel line and always turn off when storing.
Sep 12, 2017 | Garden
Won't start
The carburetor isn't letting fuel into the engine. Check for a stuck float, a stuck inlet valve (attached to the float) or the fuel shutoff solenoid on the bottom of the Carb.
Mar 11, 2016 | Garden
My hilux 1kd-ftv wont start 3.0 d4d return fuel line full pressure
if it is a common rail diesel then the pressure in the return line would burst it as the line is not capable of 25.000 psi
so the return line will have low pressure if it is blocked some where
have the injectors tested as there may be a tip seat problem that prevents it from starting and the compression pressure is making the pressure in the return line past the needle
Sep 16, 2015 | Cars & Trucks
No water going to ice maker and water dispenser in the door. replaced the "dual water inlet valve" 2 weeks ago and thought the problem was solved. No problems until yesterday when the same thing start
If your water line to the refridge has a shutoff where it is connected into a house water line, this shutoff can become plugged up. A lot of them have a needle type shutoff that when screwed in shuts the water off. This is where the house line gets punctured. When screwed out this little hole can become plugged up.. Screw shutoff in and out a couple of times and if you can disconnect line from this shutoff. Then open the shutoff and see if you can get water out of it. This may allow you to flush the hole and debris out of the shutoff. Then reconnect line and see if this helps. If it happens again you may want to replace the shutoff valve with a new one.
Dec 12, 2014 | Maytag Refrigerators
Fuel filled up air intank, lawnmower been sitting for 2 year.2003 troy-bilt riding mower
Ethanol gas ruins the Needle Valve tips and Valve Seats. This allows gas to get past them even when the Float is up causing the Needle valve to close. I bet your Oil is full of Gas as well.
Change oil, Add a Gas shutoff in the gas line and from now on shut the new Shutoff OFF a few seconds before turning off the Mower. OR by a new seat and needle valve for the Carb.
Jul 30, 2014 | Garden
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Culligan Gold series softnerdrain line runs constantly in street.
The main piston/sealpack is frozen up and needs to be replaced. There is a retrofit kit available from Culligan to repair this issue. The reason it stops when bypassed is the water is shutoff to unit.
RJ
Jul 25, 2010 | Culligan Sediment Water Filter Heavy Duty
Idles but dies when accelerated
Sounds like fuel flow restriction. Since you've replaced the fuel lines already try this....Remove and clean the carbureter needle valves and seats...Blow/**** out the inlet hose fittings ( should be 2 small brass fittings on the side of the carburetor) If you haven't replaced the lines completely (from inside the tank to carburetor) do that now.
Feb 12, 2010 | Garden
Occasionaly the engine shuts off and won't start on JD gx345.
If the fuel pump is working correctly then the problem is between the tank and the pump. run a fuel line from the pump to a gas can. If the pump is working it will siphon the fuel into your filter. If the pump is fine then there is blockage, broken fuel line (sucking air), or something blocking the pick up inside the tank.
May 23, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
