Question about Kitchen Ranges
Light stays on, convect fan won't turn on/...
5 Suggested Answers
  • 61 Answers
SOURCE: Frigidaire Gas Range with Convection--fan does not turn on
The convection fan is wired through the door switch make sure your door switch is o.k. before replacing the board or the fan. Please have a local service tech check unit if you have to get into any electical checks. good luck
Posted on Dec 26, 2008
  • 3463 Answers
SOURCE: Convection oven no longer works
Could be the fan trying to start, ,if there is a removable cover in the back of the oven, remove it and see if the fan is free to spin, could be a tight bearing , or it could be stuck with a build up of grease.
Posted on Jan 02, 2009
  • 291 Answers
SOURCE: loud fan rattling in convection mode
On the repairs I have done, it has always been a bad fan motor bearing. The only way you are going to be able to tell is to tear it down to the fan assembly and feel if the fan blade or blower is loose. Good Luck, Appliance Specialists
Posted on Jan 17, 2010
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Probe light on convection oven stays on. Clock won't display. Oven still works though.
    Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
    Posted on Aug 14, 2012
    Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
    Search Results
      Frustrated with new Samsung stove! - Forums - CNET > Forums > Samsung
      CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
      Convection 101: A Guide to Cooking With Fans - Oven ...
      Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
      New Bosch range convection fan not moving? - Home Forums > Home Forums > Appliances
      Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
      Troubleshooting Gas Range and Oven Problems ' Back ... > Tundra's Tech Talk
    Jan 17, 2016 | Kitchen Ranges
    Cooling fan below range top goes on and stays on even when oven is off
    That sure cools...
    Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
    Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
    Mar 24, 2013
    Jenn-Air SVE47600 Downdraft Fan Not Working
    Nov 30, 2010
    Jenn Air Oven SVE47500B oven light and fan stay on ...
    Nov 20, 2010
    More results from
    Nov 21, 2015 | Jenn-Air Kitchen Ranges
    Oven won't heat.
    Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
    May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
    Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
    which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
    > KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
    > KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
    > KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
    > KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
    > KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
    > KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
    > KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
    > KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
    > KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
    > KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
    Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
    I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
    Sounds similar to what mine is doing.
    Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
    I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
    Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
    Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
    Thermador RDSS30 Cooktop works fine. Oven will not turn on. Any button pushed says ''OFF''
    My Thermador CT 127 Convection Oven will not turn on. Lights work, convection fan works, oven will not heat.
    Jun 06, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
    Dec 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Fan for convection oven not working
    Maybe you could throw out the oven and buy a new fridge
    Feb 02, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
    Kenmore Convection STove - All Oven elements non-fonctional
    is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
    Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
    Kitchen Ranges Logo
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
