Question about Plumbing
My Insinkerator faucet handle is not responding...something must be loose or broken inside the handle assembly. Is it fixable?
SOURCE: Driver's door handle will not open the door
Take it to the buick dealer. As the daughter of a mechanic, it was a call I didn't want to make! The dealer installed two handles for me and painted them to match for under $100.00. Well worth the trip.
Posted on Nov 24, 2008
SOURCE: cannot open door from inside on front driverside
29 cent part my fix your problem. There is a nipple on the interior door lock lever that fits into a slot on the door handle lever. Look at passenger side to compare. The nipple is covered with a plastic spacer that may come off. The spacer keeps the lock nipple snug in the handle lever slot; pull the handle lever, it engages the lock lever, opening door. I bought a .29 cent aluminum spacer (#8x1/4 x 1/4) from Orchard hardware. Take needle nose pliers and slip the spacer on, then super glue. Unfortunately if lock lever (where riveted) is badly worn, then it may pivot upward instead of perpendicular to the door, thus defeating new spacer. But you may now be able to open door by pulling handle lever and lock lever at the same time. If you need to replace door handle, others on this site have suggested that you not replace metal frame that door handle is mounted on, but drill out rivets that hold door handle mount.
Posted on Mar 11, 2009
  • 3 Answers
SOURCE: price pfister faucet handle drops and turns off.
Re the 'falling handle' issue, I think you misunderstood the problem, jgwhomeequip. Unfortunately for me I bought *two* similar Price Pfister faucets and both had the same problem - the water wouldn't stay on and the handle just wouldn't stay up.
I took mine apart looking for something to adjust, fruitlessly. Put it back together and have lived with it like that for ~2 years.
Finally I decided to not be a knucklehead any longer and call the manufacturer. Once I got through to their rep (on a Saturday no less!) she helped me identify the model I had (a 533-50SS, just FYI), and asked me 'what finish'? I replied 'stainless steel' and she promptly replied, 'I'm going to mail you out new lighter handles to replace the ones you have'.
Brilliant! Gold star for PP for standing behind their product well past the warranty for what was apparently a common problem. Replacing the handle will take about 10 seconds per faucet.
I only wish I had got of my a$$ and called them 2 years ago.
1-800-PFAUCET (1-800-732-8238)
Consumer Service Department:
7:30am to 4:00pm PST, Mon-Sat
Fax: 1-800-713-7080
Hope that's helpful to somebody.
Posted on Apr 04, 2009
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 349 Answers
SOURCE: I have a loose handle on my Moen two hanlde
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
Posted on May 03, 2010
Moen Kleo faucet. Handle loose, removed set screw to tighten but now no water pressure. (it worked fine before inspector came for house sale)
Something always seems to happen when an inspection is due. The handle tightening operation may have affected the cartridge inside. Back off the screw and water may return. If not, the cartridge may have to be replaced.
Jun 30, 2016 | Moen Plumbing
Knob on outside frost free water faucet turns freely
remove the knob.
it might be stripped out. If not, something is broken inside. turn of the water and disassemble until you find the broken part. If it is not the knob, it might be easier to replace the assembly.
Aug 22, 2014 | Plumbing
Moen banbury faucet repair
I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
The links to the installation guide and exploded diagram are:
http://www.moen.com/shared/docs/instruction-sheets/ins2224.pdf
http://www.moen.com/shared/docs/exploded-parts-views/87017pt.pdf
Jan 18, 2014 | Plumbing
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
The swing mixer handle has become very stiff. how do i get it off to clean it/
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Aug 27, 2010 | Blanco Classic Single Handle Faucet with...
Handle is loose water flow weak
to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Ihave a two handle Moen bathroom faucet that the right handle came off showing a broken plastic part inside, how do I get the broken part out?
There is a little cap on the top of the handle, after removing in there is a philips screw under that and that will release the broken plastic part.
Mar 18, 2010 | Moen Kingsley Two Handle Bathroom Sink...
My wife turned on the hot water facute in the kitchen when she went to turn it off i will not turn off i took off the knob the nut was a little loose tightened it up still leaks is there a way to repair...
Turn the water off at the shut under the sink and open both faucets to drain line. Remove faucet handle and stem and look inside. There's probably something jamming the stem from turning. Remove that and reassemble.
Feb 21, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Turn hot handle on - water does not come out of faucet
is the feed on the bottom of the sink open . if it is shut the water off from the bottom and take apart the handle to see if something is stuck in there
Sep 26, 2009 | Moen 4551___ Monticello Popular Two Handle...
Kitchen faucet handle won't keep consistent flow
Is this a Moen???
Apr 07, 2009 | Moen Monticello Single-Handle Kitchen...
Plumbing Logo
76 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
