I have a defy electrologic 1300m and my pulsator is broken. Can it be fixed.
5 Suggested Answers
  • 15935 Answers
SOURCE: i have a defy electrologic washing machine and all
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
SOURCE: I have a Defy
my laundromaid electro logic 920 is making unususl noise when rinsing!!
Posted on Apr 10, 2011
SOURCE: I have a defy electrologic
My laundromaid washing machine is not cutting water after filling please help
Posted on May 20, 2012
  • 1585 Answers
SOURCE: Defy electrologic 720 drain pump run ccontinually without being switched on
check pressor switch
Posted on Apr 13, 2015
I have a Defy Laundromaid 1300m that doesn't let water in or start with the washing cycle need help please
Sounds like your inlet valve isn't opening. With it not opening the cycle won't start by default.
May 11, 2017 | Washing Machines
My defy laundromaid 1300m does not stop water flow, even not in use water keep flowing into the machine
there are shutoff valves behind it . use them till you get the other valves replaced
Dec 20, 2016 | Washing Machines
Defy laundromaid electrologic 920 drum wont turn
Something caught between inner & outer bowl. Nail or screw caught in inner bowl. Main bearing seized, replace seal & bearing(s).
Dec 18, 2013 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
My defy laundromaid electrologic 1300 suddenly stops spinning and gives a ue error
I had the same problem: E9 error when switching the machine on. This indicates something is wrong with the pressure switch. (or connection to the pressure switch). When you open the top cover at the back of the machine it will be in the right hand corner (when looking from the back of the machine). This is a round device with a clear tube coming in at its bottom and a three wire connecting plug at its side. When unplugging I found one of the pins corroded (green tarnish). After cleaning it off with some steel wool the problem became intermittent - indicating the connection is not too sound. Just bending the pin slightly did the trick causing it to soundly make contact inside the plug. Problem solved!!
Aug 03, 2012 | Washing Machines
I have a defy electrologic 920 washing machine and the drum will not turn
perhaps you have stumbled onto the defy feature? Classic problem.
Mar 20, 2011 | Washing Machines
I have Defy Laundromaid 1300. I was getting an E9 message.
Hi, I get an OD (wording) on my machine after washing-dosnt rinse or spin... what can that be???
Sep 21, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
