Question about Vizio Televison & Video
My vizio tv turns off when I connect hdmi cable
SOURCE: Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Posted on May 08, 2009
phongnv
  • 56 Answers
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Posted on May 12, 2009
SOURCE: eed help connecting MacBook Pro to Vizio VP50HDTV
yeah just lower your resolution on you Mac and you going to be ok
Posted on Jul 22, 2009
  • 10 Answers
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Posted on Oct 10, 2009
  • 8457 Answers
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Posted on Apr 07, 2010
Hdmi cables input 1,2,3,4 which input goes to the tuner, direct tv box, blue ray on vizio E550i-AO
The choice is entirely arbitrary. You may connect any accessory to any HDMI input. I recommend you connect the device you use most (probably your direct TV box) to HDMI 1, your second most frequently used device to HDMI 2, and so on, but it's really a question of your own preferences.
Mar 18, 2014 | Vizio E550i-A0
New iPad retina won't connect with HDMI TO VIZIO 55 m550nv tv
Sounds like your using an old HDMI cable. You need to get on that can handle HDCP. Walmart has a few decent ones that cost around $14 for a 3' cable.
Feb 03, 2013 | Televison & Video
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
How to connect nintedo to plasma tv
Hi,things you will need,
  • Video game console
  • HDMI cable
  • Audio/visual cable.
  1. Plug in your video game console's power source.
  2. Connect one end of the game console's audio/visual cable into the corresponding slot on the console if you have an older game console. If you have a newer console, insert one end of an HDMI cable into your console's "HDMI OUT" port.
  3. Plug the red and white ends of the audio/visual cable into the corresponding red and white audio inputs located on the back of your Vizio plasma TV if you have an older game console. Plug the yellow cable into the yellow "Video In" input. Depending on which model of Vizio TV you have, the yellow input may be located either right next to the audio inputs or it could be located a few ports away.
  4. Plug an HDMI cable into one of your TV's "HDMI IN" ports, if you have a newer console.
  5. Turn on your video game console and your Vizio plasma TV. Press the "TV/VIDEO" button on your remote to cycle through the various inputs. You should eventually get to an input that's displaying your video game console's home screen.
I think that will do.
Have nice day.
Sep 25, 2010 | Nintendo Video Game Consoles & Games
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
Vizio Model#:L37HDTV10A After unpluging the HDMI cable & reconnecting it back, I don't have no more HD picture. The Component cable & HD antena works but no HD brodcasting with HDMI connection....
May 11, 2009 | Vizio L37 Television
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
23 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
