Question about GE Microwave Ovens
How do I remove a GE Spacemaker JVM64 microwave oven?
All four bolts from the top are removed but the oven won't budge from the wall.
  • GE Master
  • 20,350 Answers
You consult the installation instructions and work backwards. Main link is for yours specifically. This link is general I think. There is a mounting plate at the rear.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40247.pdf
GE JVM6175SF1SS Installation Instructions Manual
Posted on Dec 26, 2016
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Trying to remove an old GE Spacemaker microwave JVM140-001 and can't figure out how to detach it. I do not have a manual or installation instructions.
On some of these old GE Spacemaker models, there are two long horizontal bolts at the top (R&L corners), accessed behind the upper grill. Remove the grill (four tiny screws), take out the two bolts (flat screw heads) that attach to the rear plate, and your microwave will come right down and out, providing you've removed the three mounting bolts on the top.
Dec 11, 2010 | General Electric Microwave Oven
Can't remove old spacemaker from wall
You can download GE owner's manuals and installation instructions here.
Apr 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL Microwave Oven Model #JVM1460WA1- After removing the 3 bolts at the top, what are the next steps to remove the oven?
Jun 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I can't remove my GE spacemaker microwave from the wall
should only be two phillips head screws in the grill holding it.tilt top out first and lift out. if the metal above is smashed down on grill the screws thru the bottom of upper cabinet need to be loosened,< not removed just loosened > and this should help. Some models slide one way or the other to release tabs also.
Apr 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Can't remove under counter microwave.
I think there are only three very long bolts that can be used to attach this microwave to the cabinet floor or shelf. Grease, paint, varnish all can make the case stick to the cabinet. You might try running a putty knife or scraper around all the exposed edges keeping the top bolts in place so it will not fall down.
Aug 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
