Question about Vacuums
I have a karcher a sc3 for my floor nd ive put it on high steam and held the back button in by the handle but it is soaking my floor
5 Suggested Answers
SOURCE: My machine is producing steam, but not sucking it back up so floor just getting wet - any ideas?
will spray but will not **** up water.
Posted on Apr 23, 2010
VacuumRepair
  • 438 Answers
SOURCE: DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
Posted on May 07, 2010
heatman101
  • 43501 Answers
SOURCE: when i push the handle there is no steam to clean the floor
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
z
Posted on Sep 25, 2010
heatman101
  • 43501 Answers
SOURCE: my Bissell steam cleaner appears to have suction
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghjd
Posted on Sep 30, 2010
Steam cleaner doesnt spray water anymore
Hello, this is Ava with Think Crucial.
Check to ensure there is a full tank of Bissell Hard Floor Solutions and water. - Make sure the clean water tank is inserted properly by removing the tank and re-inserting it. Ensure the gasket is attached to the water tank and did not fall into the machine. Reattach this gasket if necessary. - Check the valve on the bottom of the clean water tank. The water should come out of the X-valve when pressed. If the valve is blocked, soak the cap and insert in hot tap water until the blockage clears. Check the handle to ensure it is installed properly. Remove the handle and re-attach, making sure the handle is pushed down all the way. If you need to re-install the handle, remove the solution tank and lift the tab as you lift the handle. Check to ensure the solution tube is inserted properly into the floor nozzle. Clean the spray tips by bending a paper clip and inserting this into the spray tips to clean. If you continue to experience no spray, you may need to call Bissel at 1-800-237-7691 for further assistance.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 14, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
When steaming wood floors leaves floors wet
Kathy if you are talking about hardwood floors you should NOT use any kind of steamer ever on them .
The wood is eighter oak or yellow pine most common however cherry and moghagany on high end houses and used .
But it is all what is called tung and grove and is finished on the top olny with an interior finish that dosn't work well with moisture let alone forceing steam under it it will soak into the bottom of the wood and then the wood will start to cup become uneven on open up .
The best thing you can do if you have this problem let it dry out might take some time weeks or more .
Then rent a floor sander sand it stain it and put at least 3 coats of a polyurthane over it if you use water base poly you will need more coats.
May 08, 2015 | Vacuums
Is there a reset button on the karcher de 4002
open the lid and you will fine a red button with a clear rubber cover
press that button. When you have to reset, it is telling you that you need to descale the unit
Jun 15, 2011 | Karcher DE4002 Steam Vacuum
Hi There,
May 05, 2010 | Karcher DE4002 Steam Vacuum
I have an electrolux enviro multi steamer and have no instructions. I filled it up and turned it on and it is steaming out everywhere. The handle became too hot to use. What am I doing wrong ?
Check the handle. There is a Button which you press and hold and one which slides up and down. The slide button is so you don't have to depress the other button (when you are wanting constant steam, ie., for cleaning floors etc...).
I would suggest that the slide button is engaged (meaning in the on position), slide it back the opposite way and see if this solves the problem. Regards, Tina
Nov 15, 2009 | Electrolux Vacuums
Scunci steam cleaner not spraying steam
Unscrew the screw on the handle and remove handle. Remove rubber where top screws on. Remove two screws and the top and now unscrew the black pipe where the steam comes out. Now remove the button and see the small metal protrusion on the pot where the button was. Hit it with a hammer a few times softly to remove the scale buildup until the metal starts moving in and out again. I also sprayed it with a little silicone spray. Now put everything back together again. My steamer now works beautifully again!
May 24, 2008 | Scunci 52067 Handheld Steam Vacuum
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
