Question about Watches
New quartz watch not working? - Watches
2 Suggested Answers
  • 56 Answers
SOURCE: New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
Posted on Jan 24, 2010
Is the Invicta 1613 a quartz, automatic, or manual wind?
if it's a qoartz it will av it printed on the face of watch
Dec 12, 2012 | Invicta Watches - Womens 1613 Watch
Hi, I found on a street market a MIYOTA T241 watch in original package, also a plastic shield on the glass. Now the problem: May be the liquid of the battery destroyed any power supply wires or contacts. I...
mcdevito75 here, Once the battery leaks it destroys the quartz mechanism. Even if you find a replacement quartz, you"d need special Jewelers tools to remove and replace the quartz, even with that you could destroy the new quartz if you can find one. Best Bet, see a small watch repair shop in your area for a quartz replacement approx. $75.00
Sep 29, 2010 | Watches
What is the main internal assembly of the Casio forester watch called? Replacing the battery does not work.
mcdevito75 here, The Internal workings of all watches and clocks, Quartz and mechanical is called the movement. You may have a weak or even dead battery, even if the battery is new. If you"ve dropped your watch, got it water logged, you could have hurt the Quartz movement. It'll take special equiptment to check the Quartz movement to see if it"s burned out. I would try another battery or at least double check this batteries instalation in your watch. For more info, here is Casio"s contact number, 800-435-7732 9AM--5PM EST.
Aug 03, 2010 | Casio Forester PAS400B-5V Wrist Watch
Watch not working!... no use if i put a new battery..... the guy says i had to change the battery immediately and now my watch got spoilt by the old seems it leaked and spoilt...... now how...
mcdevito75 here, Sadly, once a battery, any battery leaks, it leaks out acid that eats away metal. Once your watch Battery leaked acid, it ate away electrical contacts, wires as thin as hairs, and tiny linkages with--in the quartz movement of your watch, ----- there is no reversal of this acid corrosion. You have 2 choices, 1 and if this is possible, have your watch repair person replace the quartz movement with a new one, if replacement movement is available, and 2 replace the entire watch. Sorry.
Jul 10, 2010 | Armitron Digital Sport 406623BLK Watch
New battery want work? I tried two new ones and nothing worked? Need help.
mcdevito75 here, You may need to start your watch by pressing the MODE button. Most quartz watches will stop once you"ve changed the battery, of course the possibility is there that the watch quartz has burnt out also. See a small watch repair shop in your area.
Jun 30, 2010 | Fossil BQ9177 Wrist Watch
My swatch model is swatch irony YSS112G. It stops working and when i took it to swatch shop the assistant told me its due to the mechanical problem since a new battery was restored. i was told that it was...
mcdevito75 here, Once any Quatrz mechanism goes, it"s ususlly gone. New replacement Quartz mechanisms are sold but just the mechanism itself could cost $30.00---$70.00 then the labor to have it installed, A Swatch watch is a COLLECTABLE item, it may be worth the expense of a new Quartz Mechanism, spaek with the watch shop about details.
Jun 27, 2010 | Watches
Coil shotage of Bertolucci watch
mcdevito75 here, Sounds like you need a new quartz mechanism for your expensive watch, contact your watch company online, ----- Your watches name or check with any jeweler, watch repair in any large city in India. A new quartz mechanism and work is expensive depending on the value of your watch, it may pay just to replace the watch.
Jun 24, 2010 | Bertolucci 18k Gold Diver Watch for Women
Jan 24, 2010 | Timex 27191 Wristwatch
Seiko flightmaster fitted new battery watch wont work atall
Most likely the watch was damaged when the battery was installed. Quartz watches have fragile parts in them. The coils for instance are made of wire thinner than the hair on your head. It takes almost nothing to damage these wires and the coil. Dirt is a big problem. Since a quartz watch has no force behind the gear train the smallest particle of dirt can stop a quartz watch.
Either your watch will need a cleaning or damaged parts will need replacing.
A qualified watchmaker can do this work and get your watch back in working order for you.
Hope this helps,
Yellowstone Watch Inc.
Oct 31, 2009 | Seiko Diver's Watch
Can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Jan 05, 2009 | Croton Watches
Watches Logo
14 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
