Question about Logitech Audio Players & Recorders
Left hand speaker not working on logitech z 150 speakers
nkprl
  • 54 Answers
SOURCE: left speakers not working
tell me what sound card you have
Posted on Nov 24, 2007
  • 84 Answers
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Posted on Feb 11, 2008
ulysis
  • 34 Answers
SOURCE: front left speaker is louder than the right one
JUST ADJUST THE BALANCE IN THE VOLUME CONTROL, YOU CAN FIND IT IN THE CONTROL PANEL OR AN ICON AT THE BOTTOM RIGHT OF YOUR SCREEN, THE RIGHT NEXT TO THE CLOCK.. PLEASE VOTE FOR MY POST
Posted on Oct 29, 2008
SOURCE: Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Posted on Dec 06, 2008
SOURCE: for my logitech z-4 speakers,
googled the same exact prob. and found this forum. after reading through the postings to get some ideas, I went back to my speaker set and unplugged the serial port that hooks up to the remote. blew on the connector and plugged it back in and VIOLA! I got sound from the left speaker again! Must be my awesome, smelly breathe that woke up the left speaker....
Posted on Mar 08, 2009
If one speaker is missing, will that affect how the others work, please?
running a audio system with a speaker missing damages the circuity. The speakers may well be paired, which means if one is missing, that channel will not be inoperative.
Aug 05, 2017 | Logitech X-530 5.1 Channel Speaker System...
I hv windows xp installed in my computer...i bought logitech s-150 usb digital speaker and its not working on my computer...plz help me out...
Sis you connect it to the right port of the computer system?
NOTE right port is the port with the green colour, then asie that is your system speaker working with another speaker ?
if not then you have to install your sound driver first there after try using you speaker and you are good to go,
if all this option are not working, you have to check your device very well.
remember to rate me
Jan 05, 2011 | Logitech X-530 Computer Speakers
I got a set of Logitech S-150 USB digital speakers for Christmas, and the very first time I plugged them in (and every time since) they have been very unbalanced. The right speaker seems to be fine and can...
Logitech are usually good speakers, I have had them for a long time and would suggest that there is a problem with the speaker in question. My advice would be to return them for a replacement
Dec 29, 2010 | Logitech S150 2 Speakers
Audio
Set the mic as default
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
May 30, 2010 | Logitech Quickcam Chat Webcam
The inbuilt Mic of Logitech WebCam C120 is not working.
You may not have designated the webcam mic as default
TEST SPEAKERS
Restart computer
Configure to your chat program
May 25, 2010 | Logitech Webcam
Logitech quickcam pro 9000. computer does not recognize the microphone. Under devices, not enabled & no drivers, I enable & download drivers, but still no mic. picture great. all other sound...
TEST SPEAKERS
In lower dropbox display "Use this device enable" click OK
Restart computer
Feb 02, 2010 | Logitech Webcam
Z-2300 Left Speaker and port dont work
did you try plugging in the other speaker into the yellow output. If you can hear music doing that then its only your left speaker that is the problem. Try tapping the faulty speaker into the palm of your hand while connected. There might be a faulty contact to the actual cone of the speaker. I had to open mine up because i had the same problem. It turned out that it was the wires that weren't making contact. I scrapped and moved them around connected the speaker and it worked. I hope that i made some sense out of this. good luck.
Sep 06, 2009 | Logitech Z-2300 Computer Speakers
I have Logitech X-230 speakers. The left speaker
CHECK THE POWER SUPPLY TO THE SPEAKERS
REPLACE ITEM IF POWER TRANSMISSION IN NIL
Jul 18, 2009 | Logitech X-230 Computer Speakers
Logitech x230 speaker system right hand speaker stopped working
speakers do unfortutionly go bad better just to buy another speaker just watch the ohms should not be more than 8 ohm speaker. please make sure you can return if you buy incorrect.
Nov 18, 2008 | Logitech X-530 Computer Speakers
Problems with my Speakers
these speakers come with a 2 year manufacturer warranty. a friend of mine had a similar problem and they just sent him a new set of speakers. try contacting Logitech, maybe you'll get lucky too!
Nov 26, 2006 | Logitech Z-5300 Computer Speakers
85 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
