Question about Furniture
Electric recliner chair. Lift mechanism OK. Wooden frame at base of right hand arm rest broken after owner tripped & fell across it while getting into chair.
2 Suggested Answers
  • 39039 Answers
SOURCE: I just bought this Home Meridian Comfort Lift chair at Sam's and it worked fine in the store, but when I get it home it won't recline or lift properly. I kept trying to get it to function with
The chair needed to be returned before any repair was made. It still is not working right
Posted on Dec 13, 2012
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
https://www.youtube.com/watch?v=0P4cHbjiJmc
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
Lubricating life chair
Most manufacturers have a lifetime warrantee on the frame. You would have to check and see. If you decide to just oil the joints the get rid of the squeaks, the best oil to use is either 3 in 1 or sewing machine oil. They are light and don't have a strong smell
Nov 17, 2013 | Golden Technologies Electric Power Recline...
My hand controler for lift chair is broken
hi all meridian phone number is (800) 994-3390 we had the same problem remember there is a 1 year warranty so your replacement remote could be free
Feb 05, 2013 | Home Meridian Comfort Lift Recliner
Liftcair won! tgo back to recline
Hi
I have found this site for you, You should be able to search for your chair. Once you have found your chair it should also bring up the manual option. Maybe the manual will be of help.
http://www.pridemobility.com/liftchairs/findyourliftchair.asp
Sep 15, 2012 | Pride Gl 358L Electric Lift Chair Riser...
We live in a small apartment but would love to have a recliner to sit back and relax on when we come home from work. Is there such a thing as a smaller sized recliner that will not be as bulky and can fit...
Yes, you can a wide variety of small sized designer recliner in one of the best reputed place which is Loveseat Recliner.
Some of the attractive recliner available here are:
a. CLASSIC AND TRADITIONAL BROWN BONDED LEATHER RECLINER
b. COASTER HOME FURNISHINGS MOTION
c. RED LEATHER RECLINER CLUB CHAIR
d. SWIVEL GLIDER RECLINER CHAIR
e. ZERO WALL RECLINER CHAIR, and much more.
innovative-textile-solutions-plush-wing-recliner-protector-recliner-covers-5bjzt1amsw5yuu0bttpforya-3-0.jpg
Aug 09, 2012 | Furniture
My Golden Technologies Comforter Series recliner/lift chair won't recline or lift. The buttons light up but nothing happens.
With Golden Technologies chairs, there is a self diagnostic system. There are LED lights at the transformer and the hand control. If you do have have lights at the transformer, it may be a power issue or a bad transformer. If you have lights at the transformer but not the hand control, it is the hand control. Since you state you ahve lights on the hand control, it is probably a motor issue.
The best thing you can do is call the store which sold you the chair or call Golden directly at 1-800-624-6374. While they do not sell directly to the public, they can point you to a local dealer who can help with the repair.
Sep 16, 2011 | Golden Technologies PR 501T 28D Comforter...
Can I or how can if possible return the Pride Lift Chair to normal seating position manually.Thank you.btrapp@sasktel.net
The easiest way to do this is to tip the chair forward so that the top of the chair and the arms are on the floor. The weight of the chair will be off the lift frame in this position. Look at the motor and you will see it connected to the frame with 2 hitch pins.
It is easiest to remove the top hitch pin which will now be on the bottom because the chair is upside down. Pull the clip (looks like half of a paper clip) from the pin that goes through the square chair frame and motor round tube. Pull out the pin by lifting the bottom of the motor slightly(now at the top because the chair is upside down)with your left hand and pulling the pin out with your right hand. Find the two nylon washers that have fallen out when you do this.
Swing the motor tube out of the way toward the front of the chair. Hold on to the pin, clip, and 2 nylon washers for re-assembly. Hope this helps.
Dec 26, 2010 | Pride Mobility Products Casual CL30KD Lift...
Legrest try to put them on
open up leg rest lever(spring loaded) and put on to pins from base of chair. Usually easier to put on in the open position (as if you were getting out of chair)
Mar 22, 2009 | Viper Plus Lightweight Reclining...
Can't get the base off
On the front of the seat, under the harness adjuster, there is a handle to pull to recline the seat. Pull it, while pushing back on the top of the seat to fully recline it.
There is a metal bar going across the base. Facing the front of the car seat, there is a tab that says "press" on the right hand side, under the bar. Press the tab, while pushing the bar through from the left side until you can pull it completely out.
Pull on the recline handle again and lift the seat off of the base.
Jan 25, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Furniture Logo
97 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
