Question about Razor Toys
Is it ok if I leave the charger plugged in after my razor 650 is fully charged?
3 Suggested Answers
  • 7 Answers
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
  • 8 Answers
SOURCE: Razor ground force battery says its fully charged but gokart wont turn on
Here is the owners manual for the future (in case you don't have one.)
It sounds like the push button fuse next to your charging plug. Push that in and try again. Otherwise it could be a wiring defect.
Posted on Aug 23, 2012
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
on Jun 19, 2015 | Razor E100 Electric Scooter
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
How long do you have to charge it for? , and do i leave it on or off?
the Razor MX350 will accept a charge if powered on or off, charging time is 8 hours, if the green light shows before this time still leave it plugged in as it may not be reading right.
Jun 25, 2011 | Razor MX350 DIRT ROCKET - BLUE
Philishave8890 when the razor states fully
It sounds like the battery pack needs replaced. You will find the correct battery type at See link below. You will need to order 2 batteries
To replace, you will need to remove the back cocer by removing the two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Sep 26, 2010 | Philips Health & Beauty
Razor charged but not running
You didn't specify how old you model is.
Generally I would say, the battery is failed.
You might try taking it to whereever you bought it and politely ask for a replacement. Its also a good idea not to leave these in cars during sub freezing weather.
Apr 09, 2010 | Norelco Cool Skin 7775X Electric Shaver
Re - Lumix Panasonic DE- 994 battery charger ??
Hi Cyril,
In theory this charger is fully automatic and stops the charging process once it detects that the battery has been fully charged (it will not restart charging until the battery has been taken out + put back in).
Of course, as with any electrical item, it's probably safest to unplug it if you're not planning to use it for a long time (e.g. weeks.)
Hope this helps.
Jun 11, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Using USB in car as external power
the unit uses power EQUAL to what it is being charged with, when plugged into the USB.
you need to leave it on the DC (cigarette lighter) charger overnight to charge it fully, or use an AC plug for the Motorola Razor (min-USB) to charge it in the house
Feb 12, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Won't charge up, won't run
uh...the charger's supposed to have a DC output
Feb 12, 2008 | Norelco Advantage 6705 X Electric Shaver
Toys Logo
35 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
