Question about Belling Ovens
I have belling freestanding double oven but the tempertures have washed away how do i know where tempertures are
4 Suggested Answers
jmgldsmth
  • 1889 Answers
SOURCE: Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
Posted on Apr 26, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have a maytag double oven freestanding gas
This is your dual ignitor on this oven that has gone out
Posted on Oct 21, 2009
richroth
  • 9472 Answers
SOURCE: I have a Jenn-Air Double
Have you tried to reset the breakers? The fault codes for Jenn Air all begin with F, like F4, F5, F9, etc. What is your model number?
Posted on Aug 06, 2011
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
Belling oven & grill not heating ,element been testing by electrician and seems to be ok, fan and lights working
hi you dont mention the model but all bellings have a thermal cut out (Limpet stat) the formats have one on the right hand side . remove the side panel to get to it . other models may be at the back, Also can be under the hotplates if freestanding cooker. look for a button sized cylinder 15mm dia 10mm deep with 2 wires connected. or follow a common wire back from the elements( one of them will go there).
Nov 20, 2010 | Belling Ovens
The oven temp is 100 degrees hotter than the set temp.
On most oven temperture controls, if you pull the knob off there is an adjustment screw down in the shaft turn counterclock wise?? to lower setting. Good luck
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Do i need to use a housing unit with the Belling XOU70FP Double Built under electric oven
Not if you you don't want to, it can be used freestanding if you so require.
Please rate my solution.
Thanks.
Aug 06, 2009 | Ovens
My belling oven door
get these instructions and look at door removal
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
if the glass has come away from the metal inside doror its was originally secured by a silicone sealant/adhesive. Try Toolstation 59104
Jan 29, 2009 | Belling XOU487 Electric Double Oven
Belling builtin electric cooker formula multifunction double oven think 488BH no instruction book dont know how to use the timer and different parts of fanoven etc.
get manual here
good for 60 days only
Nov 09, 2008 | Belling Ovens
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
