WHAT MIGHT BE THE TROUBLE. - Office Equipment & Supplies
  • David Ellis Rhea Dec 26, 2016
    Hi MICHAEL , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? With what?
The answer about code u6-03 in sharp arm351n
Sharp ARM351 Code: U6-03
Description
Desk No. 3 tray/LCC2 lift-up trouble
Causes
Sensor trouble Tray trouble Defective connection or disconnection between the PWB and the motor. Desk control PWB trouble Lift-up motor trouble
http://printcopy.info/?l=en&mod=erc&brand=Sharp&model=ARM351&code=U6-03
http://www.incos.it/download/SHARP/Manuale_di_servizio_ARM351_ARM451.pdf
Sep 09, 2016 | Sharp Office Equipment & Supplies
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
What is the error code e7-80 on a Sharp ar-m450u ?
E7-80 MFP-SCU PWB communication error
Cause
SCU PWB connector connection trouble.
SCU PWB - MFP PWB connection trouble.
SCU PWB mother board connection trouble.
SCU PWB trouble.
MFP PWB trouble.
Mother board trouble.
Check & Remedy
Check connection of the SCU PWB, the MFP PWB,
and the mother board.
Check the ground.
Replace the SCU PWB.
Replace the MFP PWB.
Replace the mother board.
Mar 10, 2015 | Sharp Office Equipment & Supplies
Sharp mx-2700n code f2-65
Toner motor trouble. Toner density sensor trouble. Connector/harness trouble. PCU PWB trouble. Toner cartridge trouble. Developing unit trouble. Toner transport pipe section trouble
Jul 07, 2014 | Canon ImageRUNNER 3570 Copier/Printer
Our Xerox Phaser 4500 printer has printer cooling fan error. Call Service - Code U5
U5 00 SPF COMMUNICATION TROUBLE
U5 16 SPF FAN MOTOR TROUBLE
U5 30 SPF TRAY LIFT-UP TROUBLE
U5 31 SPF TRAY LIFT-DOWN TROUBLE
U5 40 SPF INSTALL TROUBLE
For more help visit cbr tech solutions
Feb 10, 2011 | Xerox Phaser 4500 Printer
Copier displays H4 error code and would not copy
detail for error code H4: Fusing section low temperature trouble
•The set temperature is not reached within the specified time (normally 3 min) when warming up or resetting from pre-heating. Cause:
  1. Cause thermistor trouble
  2. Heater lamp trouble
  3. Control PWB trouble
  4. Thermostat trouble
  5. AC power trouble
  6. Interlock switch trouble
Solution:
  • If the heater lamp blinks normally:
  1. Check the thermistor and its harness.
  2. Check the thermistor input circuit in the
  3. control PWB.
  • If the heater lamp does not light:
  1. Check for heater lamp disconnection and
  2. thermostat disconnection.
  3. Check the interlock switch.
  4. Check the AC PWB and the lamp control
  5. circuit in the control PWB.
good luck
Oct 13, 2010 | Sharp AL-1457 Black and White Copier
Im getting the code H4-00 need to fix it
Thermistor trouble
Heater lamp trouble
Control PWB trouble
Thermostat trouble
AC power trouble
Most likely problem is the thermistors.
Aug 16, 2010 | Sharp AR-M455N Copier
What is code H4-01
H4 01 Heat roller low temperature
detection (HL2)
•Under the ready state.
(An input voltage of 1.21V or below is
detected 5 times continuously.)
Cause
thermistor trouble
Heater lamp trouble
Control PWB trouble
Thermostat trouble
AC power trouble
Use DIAG (SIM5-2) to check the heater lamp
Blinking operation.
control PWB.
Use DIAG (SIM14) to cancel the trouble.
Jan 25, 2010 | Sharp Digital Imager AR-407 Black and...
Air bag sensor keeps flashing
If a concern is detected, the air bag control module will communicate by flashing the warning indicator. A diagnostic trouble code (DTC) is logged by the air bag control module in a nonvolatile memory. For additional information, refer to Diagnosis and Testing in this section.
Lamp Fault Codes (LFC)
Item Part Number Description 1 One flash cycle: Driver air bag trouble code 2 Two flash cycle: Passenger air bag trouble code 3 Three flash cycle: Trouble code common to both driver and passenger air bag circuit 4 Four flash cycle: Safety belt pretensioner trouble code common to both driver and passenger pretensioner circuits 5 Five flash cycle: Driver side air bag trouble code 6 Six flash cycle: Passenger side air bag trouble code 7 Not used 8 Not used
Apr 10, 2009 | 2001 Ford Focus
Airbag flashes 10 times misses a flash then repeats
Try clearing the codes & see if it returns. I do not see a code fault 10. Starts at 12.
Section 01-20B: Restraints, Passive — Supplemental Air Bag System 1995 Town Car, Crown Victoria, Grand Marquis Workshop Manual DIAGNOSIS AND TESTING Diagnostic Trouble Code Clearing Procedure to Clear Diagnostic Trouble Codes from Diagnostic Monitor Non-Volatile Random Access Memory.
Normal Operation
The air bag diagnostic monitor (14B056) continually checks the air bag system for readiness. When a fault condition is detected, the DTC associated with that fault is stored in the air bag diagnostic monitor's Non-Volatile Random Access Memory (NVRAM). After writing the DTC to NVRAM, the air bag diagnostic monitor signals the fault by flashing the appropriate diagnostic trouble code on the air bag indicator. The diagnostic trouble code written to NVRAM is permanently stored in the air bag diagnostic monitor until cleared by the diagnostic trouble code clearing procedure.
  • Upon each cycle of the ignition switch (11572) , the air bag diagnostic monitor checks for diagnostic trouble codes written in NVRAM. If any diagnostic trouble codes exist in NVRAM, the air bag diagnostic monitor will then check to see if these fault conditions are still present.
  • If the conditions of the diagnostic trouble code in NVRAM are still present, then the air bag diagnostic monitor will use the air bag indicator to flash out the diagnostic trouble code number that was written in memory.
  • If the conditions of the diagnostic trouble code are not still present (indicating an intermittent or serviced fault), the air bag diagnostic monitor will use the air bag indicator to flash out a DTC which is the sum of the diagnostic trouble code in NVRAM plus 40.
Example: Due to corrosion, high resistance develops on the driver side air bag circuit. The air bag diagnostic monitor stores a diagnostic trouble code 32 in NVRAM. Upon each cycle of the ignition switch , the air bag diagnostic monitor checks the resistance of the driver air bag circuit.
  • If the resistance is still high, the air bag diagnostic monitor causes the air bag indicator to flash out a DTC 32.
  • If the resistance falls within the normal range due to service or an intermittent condition, the air bag diagnostic monitor causes DTC 72 to be flashed on the air bag indicator.
Once a fault has been serviced, the associated diagnostic trouble code may be cleared from NVRAM. Only diagnostic trouble codes that the air bag diagnostic monitor sees as repaired or intermittent may be cleared (diagnostic trouble codes 52 and above). In no circumstances can hard fault conditions (diagnostic trouble codes 45 and below) be cleared.
  1. Follow the diagnostic procedures as outlined to service the fault condition flashing on the air bag indicator.
  1. Cycle the ignition switch to OFF and then to RUN.
  1. Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
  1. Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK).
  1. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
  1. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
  1. Release short on Circuit 631 (TAN/RED STRIPE) to Circuit 57 (BLACK). This short must be released within 25 seconds after the diagnostic monitor tone sounds. Diagnostic trouble code is now cleared from NVRAM. Next highest priority diagnostic trouble code stored in NVRAM (if one exists) will begin flashing.
Feb 09, 2009 | 1995 Lincoln Town Car
27 people viewed this question
k24674
