Question about Element Televison & Video
I GOT A 50INCH ELEMENT TURNS ON BLUE LIGHT BT THERE IS NO PIC. ONLY 2 YRS OLD.
2 Suggested Answers
SOURCE: My Olevia 42 inch wont turn on the blue light isnt
Mine had the same problem. You simply remove the dozen or so screws on the back and pop the back off. If you follow where the power cord goes into the tv and trace the wires you will see a small fuse. I believe it was a 5amp and cost less than a buck. I'm not sure why mine blew but I have had no issues since.
Posted on Jan 03, 2010
How to fit an oven element
oh dear.......should of took a pic of old one...
not to worry..... just make sure you don't short them.
if theirs 2 wires it makes no difference which they go on.
if its 4 wires, follow the wires back to source...2 will go one way & 2 the other.....keep them in pairs of 2 then look at the element.
pin 1 follow round the element until comes back to pin ? put 1 of the pairs of wires on to these pins.
then put the pair of wires left on to the other pins.
just dont criss cross them & it will be fine. knock it on & test they correspond to the right setting on the oven, if not swop them over....take a pic
Sep 30, 2014 | Neff Ovens
Sunbrite tv 32 " 2 yrs old. Blue light comes on ,
Hello Joe Harlinski,
Welcome, and thank you for using FixYa!
To answer your question: Your television will have to be checked for bad (cold) soldier joints on the power supply board, as well as bad capacitors and resistors.A local Television Repair Professional should be able to handle this for you. If the board cannot be repaired, it can be replaced for roughly $75.00 to $95.00 plus the labor to install it.
Have a great day!
Nov 10, 2011 | SunBriteTV Televison & Video
Im unable to pair my H700 to my BlackBerry 8300
1.)Turn on your BT on the 8300,
2.)Press and hold the button on your H700, flip open the boom when the light turns blue.
3.)On Blackberry go to BT setup and select search, it should find it.
4.) when it askes for the PIN enter "0000" and OK
it should then be connected.
Jan 08, 2010 | RIM BlackBerry 8300 Smartphone
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Sony KDS-60A2020 turns on, then pic goes off and on off and on.
Hi:
Replace you lamp or have it replaced by a technician. Lamps are only good for about 6500hrs depending on use. Thats about close to 3yrs.
Mar 10, 2009 | Sony KDS-60A2020 60" HDTV
Whirlpool dryer model LEB6000PQ0 its not heating up anymore''it starts it turns but the clothes dont dry its only 2 yrs old.
check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
Mar 08, 2009 | Whirlpool Dryers
Element Light Stays oN
An element control switch has failed or a connection to the switch has fallen off.
Jun 09, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Televison & Video Logo
23 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
