Question about Frigidaire FAS256N2A Air Conditioner
Bad storm last night. This morning unit will come on but does not cool (no compressor) and fan setting is at the lowest. Will not respond from input either from remote or display board. Could the control board be out? Display board shows no sensor errors.
    President:
  • Frigidaire Master
  • 1,922 Answers
More than likely it ruined the capacitor for compressor, some are dual stage for comp/fan,i would ckk this first b4 getting into electronics(cap may have signs of a bulge in the case or other signs)
Posted on Jul 27, 2009
Undependable compressor
outdoor air sensor loose connection.
Jun 06, 2014 | Dometic Rooftop RV Air Conditioner
Dometic duo-therm rooftop ac unit motor wont spin unless i jiggle the wires that go into the motor then it works! Trailer sat in a monsooon storm last night. next morning compressor kicks on just fine and...
If you have to jiggle the wires going into the compressor motor to get it going, I would submit that you may very well have a broken wire or otherwise loose connection that is making contact when you jiggle the wires. If all appropriate connections were good, jiggling the wires would/should have no effect. I assume you are jiggling wires AT THE MOTOR input and not elsewhere in the circuitry. After you jiggle the wires and get it started, does it continue to run? or if not, describe more thoroughly what is happening..
Jul 14, 2012 | Dometic Rooftop RV Air Conditioner
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
Frezzer not Keeping things Forzen. I turned up the adjustment, and left it over night to adjust to new Temperature setting. I woke this morning to find everything almost completely Thawed. Fridge seems to...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Refrigerators
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 10, 2010 | Whirlpool ED5VHGXM Side by Side...
Air worked fine all last night and his morning.
if the air comes on for a short time and then turns off for 15-30 minutes, the overload protection inside the compressor is shutting down to protect the compressor. this can be caused by blocked supply or return vents, improper charge, bad valves in the compressor, and a multitude of other things. the problem will have to be corrected first.
Dec 14, 2009 | Heating & Cooling
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Running Compressor Intermittently
replace the thermastat it has a bad set of contacts
May 05, 2008 | Goldstar R8000 Air Conditioner
Frigidaire FAS256N2A Air Conditioner Logo
117 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
