Slow program change - Computers & Internet
Why is my printer going slow after only 3 or 4 sheets and almost stopping by the 5th print
First question, has the printing behaviour changed or has it always printed this way? If this is new then something has likely changed on your computer. Common problem is updates for programs like Adobe Acrobat which often cause printing problems. Try printing from a couple of different programs so you can determine if all programs are suffering this issue or if it is just one program or type of file you are trying to print.
Sep 01, 2014 | HP Officejet Pro 8620 e-All-in-One...
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Remove programs
In my opinion, you should remove the older version as it will slow down your computer a little. Unless you use the older version for testing certain software that are not compatible with the newer version, if not there is no reason to have both.
Jan 07, 2014 | Computers & Internet
Computer is too slow
Reinstall Windows and later install less programs.
Jul 18, 2010 | Dell Dimension 3100 PC Desktop
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
Slow to load programs or switch between programs
Seems to me you have defective hard drive. First of all try to backup everything you will miss in case of "hard drive death".
May be you have a spyware or some viruses. It does not matter if you have an antivirus program. Believe me ! this is crazy.
I'd suggest http://www.MalwareBytes.org : doiwnload free version update and go with quick scan. Than defragment the partition. If nothing changed, get some new hard drive and play with it. :)
Oct 08, 2009 | Acer Aspire (AST180-US340B) PC Desktop
Acer Aspire 3050 Laptop running slow Changed Hard drive, Memory, and the motherboard It still run's slow, vista basic 2 X 512 pc2 533 could it be the power board? any one had this before? Thanks..
1st go through your 'programs and features' in your control panel and delete anything over around 100Mb unless it is necessary, a lot of ram is taken up by these programs even when they are not being run.
Sep 28, 2009 | Acer Computers & Internet
COMPUTER STARTS AND RUNS SLOW.. CHANGES PROGRAM VERY SLOW.
some tips:
1. Kill unnecessary programs, you can do it from task manager.
2. some program starts at startup of PC, they make PC slow, go to start>run, type msconfig and say ok, go to startup tab and the disable the programs which you do not want to start up during PC start up.
3. downloan CCCleaner and run it.
4. Keep C drive clean as possible, move as much items to other drive, less space on c drive can slow down you PC.
5. Many files placed on desktop can make it slow.
6. If you have low memory on your PC then you have to increase it.
7. Virus or Spyware can make pc slow do thorough scanning of your PC.
8. I suggest you to uninstall any programs which are not necessary.
all the best.
2667305
Mar 13, 2009 | Dell Microsoft Windows XP Home Edition
Slow startup slow all together
The first thing I'd try to do is see what programs are running at startup. To do this Click on Start--> Run -->type "msconfig" without the quotes.
Click on the Startup Tab and view all the programs that are running at startup. As for deselecting which programs run at startup you can directly ask me which ones you can disable. For the most part all instant messengers and most program files can be disabled.
DO NOT disable any Windows/system32 files!
Jan 19, 2009 | IBM ThinkPad T30 2366 Notebook
Computer slow
you have to many programs installed on your desktop that are taking up space... also you could have a virus that can hide from the defrag..... also the F-secure program could have something to do with it.. they take up a lot of space
Jun 16, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
