Question about Kodak Cameras
Kodak k18 wont stay on unless i hold the power button
SOURCE: clarion db165
take the face off, and stick a small pin in the reset button.
Posted on Jul 24, 2008
  • 3197 Answers
SOURCE: door wont go down unless I hold the button. Also wires loose in
Your door sensors most likely have been bumped or misaligned. Each of them has a small light that should be on when aligned. Tweak them until they are lit. What is the make and model of your opener?
Posted on Jun 09, 2009
  • 83 Answers
SOURCE: power won't stay on unless you hold the button
You can't fix this problem yourself - a repair dealer needs to open up the button and inspect the power switch - call the Dyson helpline, they will find the closest authorized dealer in your area and if your machine is still under warranty it'll probably fixed under warranty for you.
Posted on Jul 30, 2009
  • 103 Answers
SOURCE: my dryer will not stay on unless u hold it thw
Start devise on motor is defective, replace motor...... call repair tech
Posted on Oct 17, 2009
redbeard00
  • 957 Answers
SOURCE: power button not engaging...vacuum will not stay
The power button is worn out and needs to be replaced. That vacuum is pretty simple. So even if you don't know how to take it apart it shouldn't cost much to have it repaired.
Posted on Nov 08, 2009
LG Sensor Dry DLE2301R power won't stay on unless I hold it down
There is a switch on the motor that could be bad or restricted with excess lint build up.
May 01, 2014 | LG DLE2514 Electric Dryer
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Where is the brushes located?
take the end cover of the generator alternator, and you will see the brush block assembley where it touches the rotor slip rings, clean the rings while you have it open
Jul 01, 2013 | Watts Onan Portable Generator - 4000 ,...
Power won't stay on unless you hold the button down . How can I fix this and what is the problem?
Jun 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kodak M1063 Camera will not stay on.
You are getting a lens error it is not fully booting up causing your issue.
May 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Wont play.. stays paused.
Turn off. Put in Hold mode. Hold down middle button. Plug in while still holding middle button. Now reformat the Clip and update the drivers.
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
Cameras Logo
74 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
