After the power button is on and ready the machine does not work. Pressing any button Powers off.
  • 25 Answers
SOURCE: powers up
This might have happened because either you keep pressing it too hard, or there is something on the micro switch on the back of the power button, try to take it out.
Posted on Nov 28, 2008
Just_Bobz
  • 448 Answers
SOURCE: powers up w/o pressing the power button
Press soft reset on back while turning ir on.
Posted on Jan 03, 2009
Steve5
  • 423 Answers
SOURCE: camera powers down when pressing shutter button
I see this frequently on the E900. Every time it has been a battery issue. If you're using rechargables (the E900 came with batteries and charger in the Canadian market......not sure about the rest of the planet), they may have just worn out over time. Replace with new NI-MH (nickel metal hydride) rechargeables. If you're using throw-away AA's, try Energizer Ultimate Lithiums. I've solved many, many E900 shutting off problems simply by changing the batteries to Energizer Lithiums.
Posted on May 27, 2009
JayBlair
  • 328 Answers
SOURCE: Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Posted on Jun 05, 2009
  • 135 Answers
SOURCE: samsung microwave 5370 buttons stopped working
Any microwave over 10 years old is not worth repairing. The touch pad is failing and parts may not be available.
Posted on Aug 27, 2009
Testimonial: "Thanks for your input."
Washer will not start
Havenison you tried pushing the door in case it isn't connecting .
Dec 26, 2012 | Whirlpool Duet WFW9050XW Washer
I have a convection bread maker. I made one loaf of bread tonight and i unplugged the machine. 30 minutes later, I tried to make a second loaf ant the menu select wouldn't work but the start and mix in...
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Jun 13, 2011 | Cuisinart Kitchen Appliances - Others
West Bend Bread Maker model 41056 does not start. When machine is plugged in, LED displays a time but buttons do not work and red light does not go on. (Pan was in machine and anchored.)
Power-Up/Start-Up Issues:
  2. Confirm the power source you're drawing from is live using a blender, toaster, etc.
  3. Plug the breadmaker in, unplug it, then plug it in a second time.
    1. Some models have a built-in off/on toggle power switch. Be sure it's turned on.
    2. Most models confirm power by making an audible beep when plugged in.
    3. Most models have a colored light and/or a lighted display screen that lights up.
    4. Most models require you press down on the Stop button until the unit powers up.
E. Some models require you press down on the Start button until the unit powers up.
F. Some models require you press down on the Select button until the unit powers up.
G. Many models require you select a baking mode by pressing the Select button before the pressing the Start button.
Q: In the end, were you able to confirm your breadmaker is receiving power?
No. Sorry to hear that. Have it serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the electronics by pressing down on the Stop button for 1 to 5 seconds. Note: A few models require you press down on the Start button instead. And even fewer require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. See reboot directions above.
Note: All breadmakers use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn during the kneading cycles, your timing belt is probably broken. You'll need to disassemble the breadmaker to visually confirm. The belt and pulley assemblies are located at the bottom of your breadmaker.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. 465ygbea
Jun 07, 2011 | West Bend 41053 Bread & Dough Maker
How do i get out of power save mode
If the computer is sleeping or in hibernation pressing the power button should bring it out of that state. If that doesn't work then you will have to hold the power button down for about 6 seconds until the system powers off completely. If all else fails pull the power cord out from the computer wait a few seconds then put it back on. The press the power button to power on the machine.
Nov 12, 2009 | Dell Dimension 4700 PC Desktop
Samsung microwave 5370 buttons stopped working
Aug 27, 2009 | Microwave Ovens
Green light flashes 3 times, but never powers on.
Most probable cause is the CP150 and the CP120 and CP114 capacitors. You can get the replacement capacitors with instructions at the following link under RCA parts category.
http://servicemanuals.vstore.ca/
Jul 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
I have a hp compaq nx7010 that powers but cant display. the screen if fine ,i have tested it on anoth machine and it is showing what can be the problem?
Try the holding the fn button and pressing the display button to change the output display from external to the initial display. If this doesn't work then attach an external display, if it works then try switching back from the external to the LCD. If that doesnt work then Hold the fn button and set the brightness of the LCD to its fullest by pressing the correct key on the keyboard.
hope this helps
Apr 23, 2009 | HP Compaq nx7010 Notebook
Powers up
Nov 02, 2008 | Nintendo Wii Console
22 people viewed this question
k24674
jasbo
jasbo
