Question about Sharp Microwave Ovens
My brand new sharp microwave drawer oven will not stay closed. The close button closes it, but then it opens
  • Sharp Master
  • 9,085 Answers
To help you, I would need your full model number as shown on the tag in or or the oven. please e-mail me here
Posted on Dec 28, 2016
Drawer tries to close and then opens
I would suspect that a foreign object may have gotten in the pathway of the drawer, the drawer actuator is out of adjustment, or one of the door sensor switch is damaged, defective, or off its mount.
The service manual is at our site here.
You can order Sharp parts from Encompass here.
Nov 02, 2012 | Sharp KB6024MW Insight Pro 24" Built-In...
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Sahrp microwave drawer doesn't automatically
It will have a one year warranty.
I would contact Sharp for their nearest authorized servicer.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Nov 27, 2009 | Sharp Microwave Ovens
Everything on my microwave works except it stopped heating food
I found this on another blog and it worked for me.
Model #KB6024MK, this is a Sharp microwave drawer that would open and close properly, but when started would not heat. These drawer units will sometimes close properly, but not enough to actuate the interlock switches to power the magnetron. A quick test is to turn the unit on and press in on the drawer handle while it is running. If you start hearing the low hum of the magnetron, the interlock assembly is out of adjustment. Removed the left side panel and gained access to the switch mounts to do a quick adjustment so when the drawer closes, the switches close properly to allow operation. It may take more than one adjustment to make it work properly so test it several times before reinstalling the side panel. It should work properly when the drawer auto closes and should not require any manual manipulation from the user.
Dec 06, 2008 | Microwave Ovens
Door Won't Close
What usually breaks is the door open lever, but sometimes there's just a grease buildup around the door open button.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If it's a Sharp or Kenmore, you can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you still have trouble, please reply back with your model number so we can help you.
Sep 21, 2008 | Microwave Ovens
Door Won't Close
What usually breaks is the door open lever.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
You can usually find helpful exploded view diagrams and order parts for most non-Sharp models by entering your full model number here.
Aug 18, 2008 | Sharp R-1505 Microwave Oven
My microwave is brand new. When I close the door, the dish rotates and the light stays on. Help!
Test 3 Door Switches. Intermittent, Skipping, Maybe Burnt internally or Spade contacts Burnt. Door switches should Open/Close or Closed/Open. A Meter or Continuity Tester Works. Audible Sound Hearing Helps on Continuity Tester. Listen for Nice Clear open-Close or Close-Open sound. If no Sound or Skips ( Intermittent ) Just found Your Problem. One of the Door Switches is Not working right. Now You Can Make & Save Money by Doing it Yourself.
Aug 15, 2008 | GE Microwave Ovens
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
107 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
