Question about Garden
The snow blower on my BX 24 started running backwards, what happened? Just replaced the shear pin on the second stage blower. Before that everything was fine.
Thanks for all the good folks that viewed my post. I finally figured it out. The chain tensioner backed off a bit allowing the drive chain to pop off it's sprocket, then the two sprockets came into contact with each other acting as a gear thus reversing the blower unit. Released the tensioner, remounted the chain, retensioned the whole thing, threw some chain oil on and bingo, my driveway is clear. Posted this in case some has the same issue.
SOURCE: Stuck garage door - Sears Craftsman 1/2 HP GDO, Model 139.18876
I HAD the same problem. I just solved it.
Here's what's wrong...
There is a black plastic "notched" wheel that attaches to the very end of the motor shaft and operates the RPM sensor. I found that when I reassembled my unit I did not get this wheel far enough onto the shaft and therefore it wasn't fitting far enough into the RPM sensor.
I had to take the motor back off, loosen the Allen screws on the shaft collar and push the collar further onto the shaft. There should be very little back and forth "play" in the shaft. This makes the RPM wheel fit further onto the shaft where it should and makes the motor work like it should.
Posted on Feb 15, 2009
  • 181 Answers
SOURCE: I want to replace the drive sprocket on my Jonsered 451E chainsaw. I found a replacement sprocket, but don't have a manual to guide me through the process of removal. How do I keep the driveshaft from
the threads are left hand.i my self use a small butterfly air rachet to remove the nut. it spins fast enough to remove the nut.
Posted on May 12, 2009
  • 61 Answers
SOURCE: homelite chainsaw sprocket and clutch for chain
You can get the parts at your local tool rental store.. They should be able to do the service themselves to if you dont want to do it.. Let me know how you make out..
Posted on Jul 10, 2009
  • 2984 Answers
SOURCE: Timing Chain Cover, Chain, Sprockets, replacement
2.2L VIN 4 To Remove:
  1. Remove or disconnect the following:
    • Drive belt.
    • Drive belt tensioner.
    • Alternator.
    • Power steering pump. Place the pump aside with the lines attached.
  2. Lift the vehicle.
  3. Remove or disconnect the following:
    • Oil pan.
    • Crankshaft pulley and hub.
    • Timing cover bolts.
    • Timing cover. If necessary, tap with a rubber mallet to loosen the cover.
  4. Clean the mating surfaces.
To Install:
  1. Install or connect the following:
    • Timing cover gasket.
    • Timing cover and the bolts. Tighten the bolts to 11 Nm (97 in. lbs.).
    • Crankshaft pulley hub and the crankshaft pulley.
    • Oil pan.
  2. Lower the vehicle.
  3. Install or connect the following:
    • Alternator.
    • Drive belt.
Posted on Aug 30, 2009
SOURCE: Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
Posted on Nov 03, 2010
Left auger does not engage/spins freely
The shear pin is sheared off. Somewhere along the auger, you'll find a hole drilled all the way through it. The shaft inside also has a hole drilled all the way through it. Compare the two augers - the holes are USUALLY in a straight line with each other (when one is up/down, the other is also up/down).
Get a replacement shear pin (DO NOT use a hardened bolt!) and put it through the holes when the auger holes are lined up with the axle holes.
Feb 19, 2014 | Toro Power Max 724 OE 24 inch 205cc Two...
Snow thrower auger won't turn
One of the grip levers should engage a clutch that controls the augers. The other grip lever should engage a clutch to drive the wheels. Figure out which is which, and track the linkage from that lever down to the gearbox between the augers and the impeller. See if there's an adjustment you can make there.
If not... the gearbox may be damaged, possibly by hitting a solid object with hardened bolts in the place of your shear pins. ALWAYS use soft shear pins!
Feb 16, 2014 | Craftsman 24" 179cc Dual-Stage Snow Blower...
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Rear auger turns front auger not turning
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
Jan 25, 2014 | Simplicity I924E 2-Stage Snowblower...
Accidently hit stick in side yard. now wont throw snow. Everything else seems good
blower might still work but gear case that runs auger is shot or you sheared the shear pins in auger
Dec 17, 2013 | Yard Machines 31AS63EE700 208cc Gas 24-in...
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
I have a honda ccr2450 and with the heavy snow today it clogged and now the auger doesnt seem to turn to speed and is slipping, not throwing snow etc, is this an easy fix. thanks carl
You have a two stage snow blower. The first stage in your auger and they are equipped with a safety shear pin. Consult your owners manual for proper pin or shear bolt replacement.
Feb 26, 2011 | Toro Garden
Only half of snow blower is turning
sounds like a shear pin, can you turn it with the machine off? Does it turn freely?
Dec 14, 2009 | Garden
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
