Question about Sony Televison & Video
Remote codes for sony hdx279w - Sony Televison & Video
    Top Expert:
  • Sony Master
  • 75,581 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Dec 27, 2016
How do i hook up my old Technics turntable to my sony hdx279w system?
Do a check, but I do not think that this system has a low level Turntable input. The typical turntable has an output of about 5 mV at peak. The typical sound level of a CD player or whatever is more like 600 mV. So you need a pre-amp t boost the level. The recent resurgence in popularity of vinyl has caused this and modern amplifiers forgot about phono inputs. More on the second link. bvelow. Sony DAV HDX279W Specs What is Phono Preamp Audio Advice
Mar 07, 2018 | Sony Audio Players & Recorders
My Sony DVD plays but there is no screen on the Sony Bravia TV. I hear the movie but no picture. The HDMI cable is plugged in. Why can't I get no picture? The TV is blank.
Make sure that you are plugged to the input of the TV and not the output. The other thing is it could easily be a bad cable. Check to make sure all cables are pushed in all the way as well. I know that sounds stupid but those are the little things that drive us all crazy but usually fix it. If none of this works let me know.
Jun 12, 2011 | Sony BRAVIA® DAV-HDX279W Theater System...
I've had my Sony Carousel CD player wiorking with DAV-HDX279W home theater system before. I used the TV/Video mode and it played. Now it doesn't. I can't find any setting that might have changed. ...
make sure the input is set to( analog in) on the stereo --this will enable the red and white jacks----it might have changed to digital which would enable the optical and coax jack--
Sep 05, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
I tried to plug Sony DAV-HDX279W into my tv with simply plugging yellow white and red into each unit but I get no sound.
common fault make sure the red and white are in the correct plugs as most units have 5.1 suround there are 3 sets of sound outputs use LF & RF
BEST OF LUCK
Aug 03, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
On my SONY DAV-HDX279W, the module that runs the rear speakers turns itself off after just a minute or two. In other words, my surround sound system won't deliver surround sound. Is this a short? Any...
are you using the speakers that come with it? its not typically recomended to use speakers not included with your htib system due to the diffrence in nominal ohms. however if you are using the original speakers check to see that the positive and negative wires are not touching. also check to see that there are no loose or cut wires if you have taken all of these precautions then most likely your unit is over heating due to prolonged use
May 24, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
I have a sony hdx279w surround system, the center speaker is not working? I can not figure this out. I also...
you have to go to system menu and press up and down until "DEC.MODE" appears then press the right arrow press up n down again put it on "PRO LOGIC" that should work it did for me .good luck!
Mar 10, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Sony hdx279w surround
Your system should come with all the cables and connectors you need for the system. The rear speakers should plug directly into the back of the system using the speaker connectors that came with your system. If you are trying to add additional speakers then you need special connectors for that type of application. You can try www.BogueEngineering.com for special connectors. Hope that helps
Feb 12, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Cannot hear regular tv through speakers
you need to purchase either rca cables or optical cable
Jan 18, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
