Question about RC Toys
I bought 4 New Bright RC trucks and they all transmit @ 27mHz and Need to change 3 of them so my kids can use their trucks at the same time. how do I do it?
  • Brett Duxbury
    Brett Duxbury Dec 26, 2016
    Hi Benjamin Hansen, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Although all on 27Mhz they may have sub channel numbers that you can switch the remote and truck to. Some remotes have channel A channel B
    orhttp://howtoadult.com/change-frequency-r...
bilink
  • 128 Answers
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
Posted on Jul 14, 2009
  • 35 Answers
SOURCE: need to find out how to adjust the RC for my SYMA
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Posted on Sep 22, 2009
ronald_kate_
  • 111 Answers
SOURCE: where can i buy a new battey and cover for tyco wheelie cycle
Hello, try E-Bay I have found many batteries for many different products over the years. Or try researching through Google, quite often you can find a lot of suppliers for different batteries ect. I hope this helps.
Posted on Nov 05, 2009
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Posted on Dec 01, 2009
  • 3 Answers
the battery isnt lasting because it needs to be fully discharged (drained) before it is recharged. (this is only for nicd batteries)
Posted on Feb 22, 2010
If I buy two rock crawlers for my kids will the signals from the remotes interfere with each other?
If they are on the same channel then yes. Most rc cars have a sticker or some other marking on the box if they are available in different channels. Usual they use 27mhz and 49mhz bands. Some use one band but have a switch to change the coding used...but this is usually also indicated on the box.
Dec 05, 2016 | Televison & Video
Remote and car different transmitting channels
Either the controller or the car has to be exchanged so that both operate on the same frequency.
Dec 30, 2013 | Sharper Image Blue Hat Toy Company Kids...
How do I change S022 frequency
They come set to a frequency the sticker on the helicopter and hand remote must correspond eg 27mHz both have to be same so if you wanted to change it you would need a new PCB circuit board and hand controller on the same frequency.
Kind regards, Julian
rccontrolfreak.co.uk
Mar 13, 2013 | SYMA Toys industrial Syma S022 Big Chinook...
I have recently bought a new Cobra 29 LTD BT(new) from the USA not realising it was 27MHz? Does anyone know if you can get them changed to 26MHz? Or does anyone do it? I'm a truckie & would li
It is stuck on 27 by design and FCC rules--those almost never will go down to 26 and if did would require extensive retuning to receive and or transmit there----sell it if you need 26 and buy a Ranger or Galaxy instead.
May 16, 2012 | Cobra 29-LTD BT Mobile CB Radio w/...
Hi ihave brought helicopter ftw 730 but the remote control was not its own .the helicopter ftw 730 remote control frequency is 40 mhz but the one i have is 27 mhz so how can i make as 40 mhz remote...
Unfortunately you can't. You will need to change the receiver or the transmitter so they are both the same frequency range eg 40mhz or 27mhz. Then you will need to check the crystal is the same frequency for the Transmitter and receiver eg 40.25mhz. NB. you can't put a 27mhz crystal into a 40mhz set or vise versa it won't work.
Aug 21, 2009 | RC Remote Control Rc Mini Helicopter
27 mhz rc helicopter will not operate. The helicopter motor runs fine when powered directly, but will not start using the radio control panel.
WE have bought the Black Hawk Heli with 27Mhz radio system to sell. The Heli's fly great and the Gyro makes them even stable. However when they feel like it, the motor starts running on its own and we had them all returned by clients. What a ******* these were. anyone may know how to rectify this radio problem. I know that 27Mhz frequency is very critical to interference, but this is upsurd.
Anyone with knowledge please give us a solution.
Regards to all. George
Jul 08, 2009 | Air Hogs Aero Ace
New bright 19.2v nicd battery problem
Mar 30, 2009 | New Bright Remote Control Toyota FJ...
Jan 17, 2009 | New Bright Remote Control Toyota FJ...
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Toys Logo
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
