Question about Motorola Mobility RAZR V3m Cellular Phone
My razor i got water on my key pad last night my pone works but it keeps hitting 4 and nine by itself
  • bigstu Nov 20, 2007
    I had the same problem so i left mine on a shelf above the radiator and the heat dried it out and it is O.K now
    Problem Solver:
  • 7 Answers
Yes, if your phone gets wet dry it out before turning it on. once dried if still not working properly take to repair shop or replace keypad yourself
Posted on Feb 08, 2008
SOURCE:
Hi there, I am using Lenovo T430 and from last 3 days my number key nine is not working except that all keys are working?
the pad is bad
get it repaired in shop.
DIY is not easy, unless skilled.
if skilled, buy a new key board,
install it, end story.
1 key fails and is bad, or got coffee in there, or? dirt
you get a Can-O-AIR and blow it out. (blow and pray?)
Sep 29, 2018 | Lenovo Computers & Internet
I have to reset the radio in my Nissan xtrail. I have the code and have put that in . The last number keeps flashing and the radio still doesn't work
Not sure if you've reset it before but here are the directions. Pay attention to last paragraph.
If you have done this sorry for not having another answer.
The trick is to know that only the channel preset button labeled 1,2,3,4 are used to enter the PIN - each channel button is used to increment the value of one digit on the display. Channel preset '1' increments the first digit, '2' the second, and so on. Each press of a channel button increments the corresponding digit by one, cycling back to 0 and around again.
So to enter 1924 as a PIN, you'd start with the display reading '0000' and press
- preset 1 once (increment 0 -> 1)
- preset 2 nine times (increment 0 -> 9)
- preset 3 twice (increment 0 -> 2)
- preset 4 four times (increment 0 -> 4)
The last one's easy, as the radio unlocks as soon as you hit the right code so you just keep pressing preset button 4 'til it unlocks! (i.e. it's a 4 digit PIN but only as secure as a 3 digit one.
Feb 06, 2018 | Nissan Cars & Trucks
Gets really hot but only for 2 short showers. Ran d/w this morning and no hit water for about 2 hrs. Tried curcuit breaker and reset button on heater worked last night.
My guess would be that the heater elements are coated very heavily with calcium deposits and are not oeperating effecient enough to keep up with use. These can be removed and replaced or cleaned but the tank itself would also be suffering the same problem. I have never tried decalcifying a tank because the age of water heaters are usually more energy and money saving to just replace. sorry
May 16, 2010 | Water Heaters
Remote control won't program.
my remote quit working. do you have a solution? thank you
Nov 14, 2008 | RCA 3-Device Universal Remote with...
Razr troubleshooting
none of the keys work and key pad is not locked. Recieved phone last night worked fine. Today I can only answer calls and only by flipping phone open.
Nov 22, 2007 | Motorola Mobility RAZR V3
Crosley Range
Here are the fault codes for Crosley ovens:
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Oct 27, 2007 | Crosley CE35100AA Electric Kitchen Range
Dropped in Water Razr V3r
ok take the circular malfuntioning pice from the key pad take out blow dry and then take out the nuclear rector funtioning log and do same with that
Mar 02, 2007 | Motorola Mobility RAZR V3
Motorola V3 Razor screen and key pads don't work
i have that same problem, razrs suck, i hate em!! my screen is black, i can make and recieve calls...but my screen wont turn on, this is the 3rd time its happened...first time just restarted it...second time i let it sit without the battery in for over night...now it wont turn on no matter what...and the shiy silver circle peice on the left of the phone, the smooth one, it broke and fell off the phone, and i lost it at school...cingular is saying that voids the warrenty...
Oct 16, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
85 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
