Question about Sony BRAVIA® DAV-HDX279W Theater System with Wireless Speakers
WhAT ARE THE REMOTE CODES FOR A SONY dav-hdx279w
SOURCE: need a universal remote control code for sony dav-dz 100
1903 will work for most functions, but not the DVD player buttons.
Posted on Dec 26, 2007
welcomejee
  • 10594 Answers
SOURCE: sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811 RM-SP350 REMOTE CONTROL
Posted on Feb 05, 2009
  • 21 Answers
SOURCE: Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Posted on Feb 20, 2009
  • 65 Answers
SOURCE: On my SONY DAV-HDX279W, the module that runs the
are you using the speakers that come with it? its not typically recomended to use speakers not included with your htib system due to the diffrence in nominal ohms. however if you are using the original speakers check to see that the positive and negative wires are not touching. also check to see that there are no loose or cut wires if you have taken all of these precautions then most likely your unit is over heating due to prolonged use
Posted on May 24, 2010
  • 3 Answers
SOURCE: need code to program Comcast Universal Remote to our Sony DAV FR9
First you need a Comcast remote with the center button, OK/Select to be grey. Now program in code 1903 to aux. Works on my FR8 System, same basic as FR9. I was unable to get Comcast remote with red center, OK/Select, to work with any codes.
Posted on Sep 05, 2010
How do i hook up my old Technics turntable to my sony hdx279w system?
Do a check, but I do not think that this system has a low level Turntable input. The typical turntable has an output of about 5 mV at peak. The typical sound level of a CD player or whatever is more like 600 mV. So you need a pre-amp t boost the level. The recent resurgence in popularity of vinyl has caused this and modern amplifiers forgot about phono inputs. More on the second link. bvelow. Sony DAV HDX279W Specs What is Phono Preamp Audio Advice
Mar 07, 2018 | Sony Audio Players & Recorders
I've had my Sony Carousel CD player wiorking with DAV-HDX279W home theater system before. I used the TV/Video mode and it played. Now it doesn't. I can't find any setting that might have changed. ...
make sure the input is set to( analog in) on the stereo --this will enable the red and white jacks----it might have changed to digital which would enable the optical and coax jack--
Sep 05, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
I tried to plug Sony DAV-HDX279W into my tv with simply plugging yellow white and red into each unit but I get no sound.
common fault make sure the red and white are in the correct plugs as most units have 5.1 suround there are 3 sets of sound outputs use LF & RF
BEST OF LUCK
Aug 03, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
On my SONY DAV-HDX279W, the module that runs the rear speakers turns itself off after just a minute or two. In other words, my surround sound system won't deliver surround sound. Is this a short? Any...
May 24, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
I have a sony hdx279w surround system, the center speaker is not working? I can not figure this out. I also...
you have to go to system menu and press up and down until "DEC.MODE" appears then press the right arrow press up n down again put it on "PRO LOGIC" that should work it did for me .good luck!
Mar 10, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Sony hdx279w surround
Your system should come with all the cables and connectors you need for the system. The rear speakers should plug directly into the back of the system using the speaker connectors that came with your system. If you are trying to add additional speakers then you need special connectors for that type of application. You can try www.BogueEngineering.com for special connectors. Hope that helps
Feb 12, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Need a universal remote control code for sony dav-dz 100
use kameleon urc remote there are a list of codes in back of manual one of the sony codes will work
Oct 17, 2007 | Sony DAV-DZ100 System
Sony BRAVIA® DAV-HDX279W Theater System with Wireless Speakers Logo
43 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
