Question about Rockwell Pro Series Rockwell RK7122L 10In Cmpnd Miter Saw W/Laser
Wiring diagram for rockwell rk7241s table saw
Switch is cutting out ,installed new switch but unit wont come on .I want to make sure I hooked up wires properly
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
220 volt wiring diagram
You might be able to get a diagram from Rockwell or the motor manufacturer.
May 19, 2014 | Rockwell 10" Table Saw with Leg Stand 13...
Switch wiring
Did you manage to get in contact with the manufacturer of your saw? They would surely help you with your problem.
May 03, 2013 | Makita MLT100 TABLE SAW FOR 220 VOLTS
Rockwell 10" Contractor's Saw 34-440
u could get a adaptor for a three prong and the adaptor would make it a 2 prong u could go to your nerest hardware store they probly have a adaptor if that dose not have it go to walmart i know they have some
Apr 29, 2013 | Rockwell Tablesaw 34-440 34-607 Front...
Looking for owners manuals for 2 saws
Your Delta radial arm saw (RS830) manual is here. Exploded diagram for parts, etc is here.
I'm not sure on the Rockwell, but here's a link to a manual for a Rockwell-Delta 10" Tilting Arbor Unisaw, circa 1969 which seems about right for a 34-466.
If that's not quite right, there a couple other manuals for old Rockwell saws here.
If this answer helped, please vote. Thanks!
May 19, 2010 | Delta Saws
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Nov 02, 2009 | Craftsman 10" Table Saw
1 HP. motor wiring, need help!
Simple to do. Go to the local hardware or home improvement store and get a 6 to 8 foot heavy-duty extension cord. Cut the outlet end (not the Plug end) off, you won't use it. Strip back the outer casing of the cord to expose the three wires, black, white and green.
The Green wire is connected to frame of the motor or saw to ground it for safety reasons.
The White wire is connected to the silver color screw connection.
The Black wire is connected to one terminal of the switch, another wire is connected from the second switch terminal to the brass color screw on the motor.
Plug in the extension cord, and flip "ON" the switch and cut some wood and think of your Grandpa....good guy!
Sep 17, 2009 | Craftsman 10" Table Saw
Owners manual
Is this a 10" contractor's saw?
I can't seem to locate that number, but did turn up a 34-348. If that's close, you may have a look at the parts list and diagram at
I hope this will prove to be of some help!
Feb 22, 2009 | Saws
Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Feb 13, 2009 | Hitachi 10", Table Saw with Stand,...
Rockwell Pro Series Rockwell RK7122L 10In Cmpnd Miter Saw W/Laser Logo
81 people viewed this question
Top Rockwell Pro Series Saws Experts
Tom Chichester
ray gallant
Are you a Rockwell Pro Series Saw Expert? Answer questions, earn points and help others
