Question about Dishwashers
The lights and heating element do not come on. The switch that controls does not light up
  • 1214 Answers
SOURCE: Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Posted on Jan 23, 2009
milten1
  • 1304 Answers
SOURCE: Heating element won't heat. Control light comes
your element is shorted
since the elemen t is welded and fitted to the bottom of the pan it can be fixed but should not be
my advise get a new one
rival will just say it has water damage
Posted on Oct 08, 2009
  • 187 Answers
SOURCE: bake element does not heat up
This would be a good candidate, but not necessarily an absolute. Selector switches, loose wires, fuses, and a few other sundries could also be the cuprit. Make sure that the new element that was installed is the correct one for your model. I am assuming that the element was replaced?
If not, by all means, check the element. Elements only last a few years. Just because the plug it plugs into has current, it doesn't mean that the element itself is any good. By far, a burned out element is the most common, easily fixed failures.
Unplug or shut the appliance off at the breaker. Pull the element and visually examine for burnt or rough spots. The elements either pull directly from the housing, or are held in place with a few screws. Bad elements sometimes look totally normal.
If the bottom and top elements are the same( they usually are) a simple check would be taking out the broiler element and then swapping for the bake element. If the broiler element works in the bake position, buy a new element and ask for a refund for the service call.
I can't understand why the service person did not pull the unit and check voltage in the control before making an absolute diagnosis. The circuit board is usually well over 100.00. The unit also sometimes comes with a diagnostic feature that homeowners/techs can use to test the "ERC" without even taking it out of the range.
If you have your owners manual, check the trouble shoot section. If not, Sears has some manuals and repair help/parts online, and Whirlpool is among the best companies in terms of customer supports. I don't know your model, so I can't be too specific with advice. The link for Whirpool has a search engine you can use for your exact model. This link is for most newer models. Among other online resources, Repair Clinic" has parts that you can order online, and they also have diagrams that can help out significantly if you do change the unit out yourself. If it is something cheap like an element, it is helpful to go to an appliance store where you can return the unit a little easier. Thanks for your question, please leave comments if you need further advice.
Posted on Dec 14, 2009
  • 291 Answers
SOURCE: My question is in regards to my Kenmore electric
It is usually always an infinite switch, Rarely is it a surface element. The fact that the power light does not go on is also a good clue that your switch is bad. If it was a problem with the wiring to the element, your light would be on. When you order the switch, ask for the exact origional replacement. They have some generic switches that have shafts that have to be broken off to the right size for your range. These are not as reliable as the origional which usually has a much stronger shaft. Good Luck, Appliance Specialists.
Posted on Jan 26, 2010
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
Belling cookcenter oven over heats and light stays on
It sounds like the people who changed the elements did not connect them to the correct wires. The thermostat seems to have no effect on the elements, and the light switch seems to have no effect on the light, explain this to them and that you think they fitted the elements directly onto the power input to the device, instead of the correct connections.
Dec 14, 2013 | Ovens
Tip
Will not power on, powers off, will not heat Pwr light out or goes out.
Like most of the problems listed on FixYa about this Deep Fryer ours worked fine the last time we used it, but we could not get the power light to come on again. I found that there is s SAFETY Micro-switch on the heating element control unit. This switch prevents the heating element from being turned on when it is not in the Fryer Pan. The accuator lever for the switch is located under the guide slides on the heating element control unit. It is a metal lever which is moved as you mount the heating element control unit on the fryer pan. You have to look closely under one of the guide ledges on the heating control unit to see it . The problem is that over time the adjustment of the lever changes as it flexes under use. I simply readjusted the lever by forming it with a pair of long-nosed pliers. CAUTION !!!!!!! You can bend the lever so far that the switch is closed all the time defeating the Safety Switch and create a hazard in that the unit will heat as soon as you plug it in whether inserted in the Fryer Pan or lying out on any surface. This might burn someone or cause a fire. Good Luck
X-IBM
on Oct 09, 2008 | GE 168997 Deep Fryer
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Miele Dishwashers
G1022
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jun 13, 2013 | Miele Dishwashers
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
My question is in regards to my Kenmore electric range, Model: 790.96219407. The left front element is not functioning. I tried replacing the left front element but this did not work. Could it be in the...
Jan 26, 2010 | Kenmore 96212 / 96214 / 96219 Electric...
MY JACUZZI HOT TUB STOPPED HEATING
sounds like it could be either the heating element, the thermostat or pressure switch problem. Does the light come on when it is trying to heat? if it doesn't come on then most likely the heating element needs to be changed.
Dec 13, 2008 | Home
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
Owen Barnes
