Lamona on off light not working - Washing Machines
Lamona
www.lamona.co.uk
Jul 03, 2014 | Refrigerators
Lamona LAM 4400 oven not switching on
may be an internal fuse / wire burnt off oven control as nothing works
Nov 10, 2013 | Ovens
I have a lamona hja3400 oven and the element has stopped working. I'm trying to get the element out but it seems to be fastened on the back of the oven not inside it as with other types of ovens. Does...
hi my lamona oven started to make a noise like a pinging noise it was working the noise would come and go it would get worse half way through cooking. but last night the noise seemed to have lasted longer and the oven knocked itself off any ideas what the problem could be.
Aug 30, 2013 | Ovens
Lamona fridge freezer
check that the temp setting knob has not been turned to zero for the fridge. The light is only to let you see what is inside the fridge and is not an indicator of the fridge working.
Jun 26, 2013 | Ovens
Lamona (Howdens) dishwasher. Start/Cancel/Pause button is not working.
Probably a bit late for the original poster, but I found this page after searching with the same problem. You can actually fix this yourself. I had exactly the same problem - if you take the front off the dishwasher, the switch module is inside a grey plastic moulding. If you remove the two cable plugs and remove the two screws holding the moulding in you can then take it out. Carefully open it by pulling back the clips, and inside is a small circuit board that slides out. On one side are the two microswitches. I got mine working again with some switch cleaner. If that doesn't work, you should be able to get a new switch soldered on by any electrical repairer. Obviously, yours may be slightly different as I don't know what model dishwasher you have, but mine is a Howden's/Lamona too, so it's probably very similar. Good luck.
Oct 07, 2012 | Dishwashers
The lights have blown on my Lamona cooker hood, is there a fuse and how do I access it?
So has mine. At a loss as to what to do as fan not working either. Any joy yet???
Feb 22, 2011 | Microwave Ovens
Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Feb 21, 2010 | Dishwashers
Washing Machines Logo
Top Washing Machines Experts
