R
Randy Pepe Posted on Dec 26, 2016
How do I adjust the length in the ptd600 label maker?
Dymo PC 10 electric label maker. Looking for cables?
Are you sure is is a 'PC 10'? I can't find that model. All the ones I have used were battery operated desktop use or hand held. Is this a cable that connect the label maker to a PC, so you design on the computer and print to the Dymo? If that is the case, It _should_ be a standard printer lead.
10FT USB2.0 Printer Sync Cable For DYMO Label Writer ...
Walmart https://www.walmart.ca > 10FT-USB2-0-Printer-Sync-...
100% BRAND NEW, NEVER USED; Cord Length: 10 feet 3M; Compatible with: DYMO Label Writer 450 Twin Turbo label printer; PC and Mac compatible ...
· ‎In stock
USB Cable Cord for DYMO LABELWRITER 310 320 330 ...
eBay https://m.ebay.ca > ... > USB Cables, Hubs & Adapters
USB Cable Cord for DYMO LABELWRITER 310 320 330 400 450 TURBO LABEL PRINTER 6ft ; Quantity. 3 sold. More than 10 available ; Item Number. 364268793499 ; Brand.
NiceTQ Replacement PC/Mac USB Data Sync Transfer ...
Best Buy https://www.bestbuy.ca > ... > USB Cables
NiceTQ Replacement PC/Mac USB Data Sync Transfer Cable Cord For DYMO Label Writer 450 Twin Turbo Label Printer. Model Number: 308139549170. Web Code: 14840651.
· ‎In stock
Dymo PC 10 search results.
https://www.google.com/search?q=dymo+PC+10+electric+label+maker
How can i adjust the label feed
Firstly the length of the label must be correctly set.
- When activation forward wait on parameter, you can adjust the feed value.
- else you can adjust the feed value in the driver.
I'm using my LP-2844 in conjunction with Label Matrix software and I've run into a snag with my printer. When switching between jobs, I went from one label size to another (something i've done...
The problem with this type of printer is that you need to callibrate the size of the label in fact the Length. If you change the length then the printer may stop printing correctly ans stalls.
From your driver try to do a calibration of sensors with your labels and this sould work with this model.
Other manufacturers handle the varying length dynamically.
Printer will not calibrate to different lengths of label stock.
I would recommend adjusting your sensor to the middle of your label.
P Touch 1880 indicates MAX font size, but prints smaller sized label. If I print one word at a time, it prints in MAX size. If I print two or more words, it prints smaller font. Weird, new problem.
Sounds like you may have a maximum length set that keeps you from printing over a certain length of label and it is adjusting your font size to fit that length. You may need a manual to figure out how to reset the length.
Loftware labels printing off staggered.
Most reasons for this is a slight adjustment problem with page length. You can recalibrate the printer via the menu system, doing it this way will adjust the sensors with new settings
Printing half the vertical, no matter what size label in use.
Some drivers adjust the length of the print area, regardless of the length of the label. Do calibrate the label and also verifies that the margins are zero.
Roberto Martinez
During manual calibration of the Z4Mplus the
Let the printer calibrates itself or have a manual calibration in the printer setup. You can also press the keys FEED, PAUSE and CANCEL, turn on the printer and release the keys when feeding the labels.
Roberto Martinez
3helpful
2answers
Mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
k24674
ADMIN Andrew
ADMIN Andrew
