Question about Sony Televison & Video
I need a replacement stand for my Sony Bravia KDL-52W4100 TV. HELP, please?!
SOURCE: 12 little horizontal lines in Sony Bravia KDL-52W4100
we have the same exact tv and it is not even a year old. we are told that it is the display panel and it is a well known problem with this tv. we were also told that there is a shortage of these parts. they had 283 on order, but only received 35. you need to call sony and tell them that you have this problem. they should warranty this for you even if your tv is 3 months past the warranty period. since this is a well known problem with this tv, keep on them.
Posted on Nov 24, 2009
Testimonial: "It in fact was a part of the lcd panel...the t-con board. I was able to research it and bought a box of parts off of a tv like mine and fixed it. Ron"
Macklintok
  • 122 Answers
SOURCE: I'm trying to source a
your best bet is probably SONY parts Dept. you can reach them by phone at: 1-800-488-SONY (7669).
or on the web at:
Sony Parts & Accessories
FYI I couldn't find your part on the web site. I recomend you call.
Posted on Sep 17, 2010
SD Tech
  • 14553 Answers
SOURCE: screw size for attaching stand for Sony Bravia LCD TV model# 46W4500
while the owner manual does not specify the length etc of bolts it does show there are 4 of them---look like find thread machine bolt---may be able to buy a few at the hardware sore or Home Depot---if the threads are inside the base take it with you as a guide.
http://download.sony-asia.com/consumer/IM/4106869131.pdf
pretty stupid as owner manual has everything including dimensions and weight etc but no list of bolts size.
Posted on May 20, 2012
SD Tech
  • 14553 Answers
SOURCE: Sony Bravia KDL-40V5100 stuck in stand-by mode
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_8_2012_3_55_52_pm.jpg6_8_2012_3_56_10_pm.jpg
Posted on Jun 08, 2012
gopakumarg43
  • 74106 Answers
SOURCE: KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Posted on Feb 19, 2013
Feb 19, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony bravia kdl- 52w4100 52 in. LCD tv
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 26, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I cant find remote for 52" Bravia tv. Can I turn
Yes, you can turn it On-Off by pressing power button on side of tv.
Required tv remote for KDL-52W4100 is available at Remotes.com
Hope these info will help you.
Thanks.
Nov 05, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
We need our Sony 52W4100 Bravia screen replaced. What is the cost?
Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV
Part # 1-802-791-12, cost approx $2,251.54 + core
Parts reference: Andrews electronics, 800 289 0300.
May 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How do I reset a Somy bravia KDL-52W4100 back to factory default settings?
While holding down the UP arrow key, press the power button. The TV will turn off and back on and reset to factory default settings. Hope this helps
Jul 05, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
We lose audio on our Sony BRAVIA KDL-52W4100
This problem appears to be an issue with numerous Sony Bravia owners of the same model. Although still seeking a soulution, it would appear that our cable provider (Verizon) has replaced all of their components and the Geek Squad from Best Buy where we purchased the unit, points the finger at Verizon. None of our other Fios-equipped TV's exhibit this problem so I am glad we bought the service plan with the TV and will continue to seek a remedy.
Mar 04, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
