Question about Home Security
Key turned 1/2 way to left. stuck. can't turn either way. can't remove key. can't turn knob either way. can't open door. everything inside.
sicaudio
  • 96 Answers
SOURCE: Driver's side door power locks are stuck; door stuck shut.
sounds like the rods are disconnected the clips hold the rods in place the latching mechanism holds the handle in place as well did you replace the speakers or did a shop? if a shop did then they caused this if you did then you may have caused this either way untill you reattach the rods none of it will work. you will have to manually open the door at the latch from inside teh door behind the panel.
Posted on Jul 19, 2008
  • 35 Answers
SOURCE: Stuck Door Knob with No Access!
I agree with your Hacksaw method. Very easy and very fast. You are going to want to replace the knob anyway so this does not happen again. Just Hacksaw that knob as close to the door as you can without damaging the door. From there you are on your way to access to the parts of the lock. Now you can replace that knob and never have this trouble again!!!! One less headache in Life......Hope this helps you ........Joe
Posted on Jan 10, 2009
  • 14 Answers
SOURCE: Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Posted on Jun 18, 2009
SOURCE: 97 Passat left front door won't open from outside
The outside door handles on 95-97 Passats have a known problem. As they age, the pivot pin for the actuaring lever slides out of one of the support posts. This changes the geometry of the lever system so pulling on the handle does not open the door. The locking mechanism will work fine as will the interior door handle. The only cure is to replace the outside door handle.I have to replace my 95 Passat's Left front door handle about every 2 years due to this problem. Do not replace with a used handle as the problem will reoccur sooner. Replacement is easy; Remove the inner panel, carefully peel back the vapor barrior from the door by the outside door handle. Unplug the wire to the door hande and remove the Phillips head screw on the edge of the door that attaches the handle to the door. Slide the door handle toward the front of the door and gently pull it off. Reverse the process to replace it. Ensure the door handle wires are not pinched by the window mechanism and replace the inner door panel.
Remove the inner door panle by removing the door lock knob along with the screws around the front and back edge of the door panel. Remove the plasic cover on the armrest/door pull and carefully remove the wires from the outside mirror adjustment switch. Remove the 2 screws from under the armrest/door pull and pull the top of panel away from the door. Once the top of the panel is about 8 inches from the door it will lift out of the clips on the bottm of the door. Revese process to reinstall. Carefully glue the plastic vapor barrior in place before you replace the door panel.
Posted on Jan 16, 2010
rsmith972278
  • 160 Answers
SOURCE: I have Kwickset door knobs on my outside doors. I
The instructions they send are almost always generic and cover more than one subject.
If you insert the key and turn it all the way clockwise, you should be able to insert the tool tip they sent you into the hole on the shank part of the handle. Pull straight out and it should come off. Some times it takes several attempts to do.
Next turn key counter clockwise back to starting position and remove key. Dump lock out of handle, paying attention to orientation. Turn lock 180 degrees and reinsert back into handle. Put lock and handle back on to door and reinsert the key. Turn key clockwise and push.... remove key.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Posted on Jan 21, 2010
I bought a DEFIANT KEY PAD DEADBOLT.
Usually you just take it apart and turn everything around, the keypad would be turned over and the bolt would be removed and turned to the reverse of where it was.
If it is the type below, I am thinking you would remove the deadbolt part and turn it and then there must be something inside that reverses the throw of the bolt. No instructions with it?
Defiant Electronic keypad Deadbolt Satin Nickel The Home Depot Canada
Nov 11, 2015 | Defiant Stainless Steel Ball Entry Knob...
New deadbolt notworking?
You have the lever that goes from the key cylinder part of the lock through the striker portion of the locking assembly turned part way, either in the wrong direction or not turned enough in the right direction so if you take the inside portion of the lock off and pull the outside portion out of the door and rotate the lever to its proper position and then put if all back together in the correct sequence it should work properly.
Sep 19, 2014 | Schlage Aged Bronze Grip Handle Entry Set...
Broken interior door knob door will not open.
well if you havent been able to get the cat out by now its dead but looking at the pics only way you can get in is by jigsawing the latch out
May 23, 2012 | Hardware & Accessories
Hope this Helps,
RSMITH972278
Jan 20, 2010 | Kwikset Professional Door Lock...
I have an emtek exterior door lock, that is stuck in the locked position. I can only open it with a key, and not even the inside unlock mechanism will permanently unlock it. I took it apart as much as i...
If the opening is on the side, it probably comes off by pushing a small tool (pick or large paper clip) into the hole while turning the key. When you feel the pin move, pull on the knob and it should come off.
Nov 19, 2009 | Top Knobs M826 Door Pull
How can i remove the paper inside the printer
For the paper jam issue turn around the printer and open the back door to pull the paper.
and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Dec 09, 2008 | Whirlpool GEW9250 Electric Dryer
Home Security Logo
54 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
