Question about Bobcat Garden
86 Bobcat with a Mikuni/Solex 28-32DID SA32. Starts and runs after 5 minutes dies like there is no gas getting to the engine.Put a kit in it which included the Float and Needle and seat assembly.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 943 Answers
Craig, make sure you pushed the seat all the way down. it sound like if you put a kit in it and it is doing what you are saying my guess is the seat isn't down all the way. causing it to starve for fuel. you might be sure the fuel lines and fuel filter are good. sometimes by replacing fuel filter and fuel line it will run as good as new. cheap fix doesn't cost that much while your on the fuel system.
Posted on Dec 26, 2016
Why BRIGGS and STRATTON 7.0hp ohv starts to die out when I start to spray it works for a min then sharts choking?
How old is the engine? Could be a dirty carburetor, stuck choke, clogged fuel filter or bad gas. Put a bottle of carburetor cleaner into the gas tank, start it up and let it run at idle for 5 minutes and then try to put load on the engine.
Jun 15, 2015 | Measuring Tools & Sensors
1988 aric cat 440 jag when primed will start and run then dies
Sounds like there is water in your fuel. If there is, you can see it in the bottom of the tank or just drain it and put fresh new gas in it. If straight fuel is left in small engines in the off seasons, they will gum up the carb with varnish and the carb will need to be removed, cleaned, and reinstalled.
Sep 21, 2014 | Garden
Engine runs but back fires then dies when put under load
Rebuild the carburetor. Just replace the old gaskets, diaphragms, needle and seat. You can get a rebuild kit from your local lawm mower repair shop. also, don't run last years gas and if you keep gas in the tank over the winter buy a winterizer and pour it in the tank when starts to get cold. Hope this helps!
Apr 12, 2014 | 5.5 HP GX160 Engine
Johnson outboard stalls when it warms up
Little Johnson outboards are famous for being very easy to start, So- first pump up the gas, then set the throttle open to the neutral stop -pull thru once -then set the choke to fully closed (look down the carb and see if it is) and pull thru 2 more times- open the choke. try again --If it is not running by now you have a bad ignition, or the engine has no compression. - very likely if you are running the wrong spark plugs. You may have some shattered reed valves.
See if the spark plugs are getting wet with fuel.
Sep 08, 2012 | Boating
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
Had a problem with my Sears riding mower late last summer. It runs for like 5 minutes then will conk out. I wait 5 minutes 10 minutes or so, it starts up and conks out again like after 3-4 minutes. I...
check your gas tank cap, it is vented, if it gets clogged up fuel will not flow properly and engine dies of fuel starvation. By waiting a few minutes you have allowed the pressure to equalize in the tank enough to get enough fuel for engine to run.
Mar 05, 2010 | Garden
Engine Stalls out
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Poulan Pe550 Gas Edger
86 bmw L7
I think your problem might be your fuel relay which is situated next to the fuse box in the engine compartment.
Jul 13, 2008 | 1986 BMW L7
Garden Logo
51 people viewed this question
Top Bobcat Garden Experts
Daryl Gleaton
Dan Apthorp
Jim flowers
Jim flowers
Are you a Bobcat Garden Expert? Answer questions, earn points and help others
