Question about Ovens
How to replace potentiometer on PRG484GGUS - Ovens
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
F 7 ERROR KENMORE OVEN MODEL 911.47169791
The F7 error code indicates that one or more potentiometers (burner switches) are not connected properly or that you have one or more failed potentiometers.
The specific details of this failure code are provided in the second image below.
This is an excerpt from the technical information for this range.
Normally, a service technician would be needed to conduct the troubleshooting and diagnosis for this type of failure.
If you are completely confident in your technical ability to safely unplug the range and access these potentiometers (54 in the third image example) you may be able to check for loose or broken wires that could be causing this code.
If no loose wires are found, then you will likely need to have a technician find and replace a failed potentiometer.
IMAGE1: http://media.fotki.com/1_p,wfdddkwdfrwkdtqxgtqsskgwtqkq,vi/gfwdtqtbrxgdkgqwqtb/1/1303472/5961857/image11662img-or.gif
IMAGE2: http://media.fotki.com/1_p,wfdddbrbbbbgfttxgtqsskgwtqkq,vi/gsfkbbsqqxgdtwdgbsg/1/1303472/5961857/image11663img-or.gif
IMAGE3: http://media.fotki.com/1_p,wfddfqsqwsbqtrwxgtqsskgwtqkq,vi/gtfggdrdwxgftrgbbtf/1/1303472/5961857/image11664img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2010 | Kenmore 30169 Electric Single Oven
I need to know whay is an error F7 on my kenmore oven. Every time I plug the oven on I get an error F7
Sep 01, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I recently installed a used Kenmore oven. After installation, I checked it's operation, everthing worked fine. Today, I am getting an F7 code and a beeping. What is the F7 code?
Aug 10, 2010 | Kenmore 47619 Electric Single Oven
I have the Kenmore model 91147642100 double oven. F7 is showing and oven will not work on top or bottom
Feb 24, 2010 | Kenmore 47732 / 47734 / 47739 Electric...
Kenmore gas oven has a code F7 on the display and does not stop beeping. The oven is also not working
Oct 29, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore elite wall oven model 911.49032 code F-7 kepps coming up on the control panel
Sep 14, 2009 | Kenmore 49233 Electric Double Oven
Error code f7 on Kenmore wall oven 911.41165791
Feb 03, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
F7 code on kenmore oven and beeps what do i do to turn it off
Nov 11, 2008 | Kenmore 42161 / 42169 Electric Single Oven
CTB temperature adjustment knob shaft
The blodgett part number you are looking for is 18234 Potentiometer remote (infinite control) I dont know if you are able to buy directly from blodgett here is the number for blodgett 1-800-331-5842 the blodgett web address is blodgett.com if you are not able to order from blodgett you might try another company generalparts the number for general parts is 1-816-421-5400 kansas city location. the web address for general parts is generalparts.com
May 13, 2008 | Blodgett CTB BASE Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
