Need to change my password - Computers & Internet
I need to change my password
hi William.
you have not said what password you want to change but see if this is it.
How do I change my password on Google? Change your password
  1. Sign in to My Account.
  2. Under "Sign-in & security," select Signing in to Google.
  3. Choose Password. If you see a prompt to sign in again, sign in.
  4. Enter your new password, then select Change Password.
Change or reset your password - Google Account Help - Google Support
https://support.google.com/accounts/answer/41078?hl=en Search for: How do I change my password on Google?
if not go to this link should help you out.
how to change my password Google Search
Dec 03, 2017 | Computers & Internet
Tip
How to Change Windows Password on Windows 7/Vista/XP?
Setting a password on Windows 7/Vista/XP can add a level of security to your computer. So you are often advised to set a password on Windows. In addition, it is highly recommended to change Windows password regularly. And it is a good habit to keep your PC security by changing Windows password. Here are some simple methods to change Windows password among Windows7/Vista/XP.
Method 1: Change Windows password by using Control Panel.
The steps to change Windows password have a little different on different Windows systems. The following steps are based on changing Windows 7 password.
1. Click Start, Control Panel and User Accounts in order.
2. Pick the specified Windows account whose password you want to change.
3. Click on change my password.
4. Enter your current password and type a new password, and then click Change Password button.
Note: you may need appropriate privileges to change the password of another user.
Method 2: Change Windows password by pressing Ctrl +Alt +Del.
It is the easiest way to change Windows password for Windows 7, Windows XP and Windows Vista.
1. Press Ctrl + Alt + Del when you log onto your Windows XP/7/Vista PC.
2. Click on Change password.
3. Type your new password, type your new password to confirm it, and then press Enter.
Note:
1. If your press Ctrl+ Alt +Del when you log onto your Windows XP, it will show you the classic security options instead. Click Change Password to change Windows XP password of the logged on user.
2. If the security options does not appear. Task Manager shows up instead of the security options. Just go to Start, Control Panel, User Accounts and Change the way Users Log on or off. And then uncheck Use the Welcome Screen.
Method 3: Use lusrmgr.msc to change Windows 7/Vista/XP password.
The following steps are operated to change Windows Vista password.
1. Click Start button and input lusrmgr.msc into the Search box.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3.Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Method 4: Change Windows password with Windows Password Unlocker
Windows Password Unlocker Standard allows you to change lost or forgotten password on Windows 7/Vista/XP.You can adopt this method to reset Windows password when you are locked out of computer without a password reset disk.
1. Download and install Windows Password Unlocker Standard in any accessible computer.
2. Run the program and insert a bootable CD/DVD or USB flash drive.
3. Burn an ISO image file to the CD/DVD or USB flash drive.
4. Set your locked computer to boot form CD/DVD or USB drive.
5. Change Windows password with the burned CD/DVD or USB drive
These are the simple methods can be applied to change Windows password on Windows 7/Vista/ XP. Of course, there are some other ways for your choice. Please remember your changed password. It is often for one to forget Windows password after changing it. Otherwise, you'll need to bypass lost Windows password with Method 4 if you are locked out of computer.
on Oct 20, 2010 | Computers & Internet
Hi, How to change Cisco IP Phone voicemail password on router. Thank you
on the CLI you need to change the username and password on the ephone for that phone. Then you need to session into the CUE module and change the password there as well. do a show run and find the username and password that you need to change and then do config t and change the password. The user can also do this on the phone if they know the previous password.
Aug 31, 2017 | Cisco Computers & Internet
Need to reset my password
Change your Google Account password To change your Google Account password, go to the change your password page.
Or you can follow the steps listed below:
  1. Sign in to your Google account. If you've forgotten your password, type your username on the trouble signing in page to reset your password.
  2. Go to the Google Accounts security tab.
  3. In the Password box, click Change password.
Remember that changing your Google Account password changes it for all Google products you use, like Gmail and YouTube, so be sure to use your new password the next time you sign in.
Aug 19, 2014 | gmail.com
Change my yahoo password
Change your password Your Yahoo password applies to all Yahoo services you use with your account. Because of this, we think it's a good idea to change your password at least once every year to keep your account information secure.
You'll need to know your password before you can update it. Not sure what it is?Use our Password Helper.
Here's how to change it:
  1. Go to your Yahoo Account Info page.
  2. Enter your Yahoo ID and password.
  3. Under "Sign-In and Security," click Change your password.
  4. In the fields provided, enter:
  5. Click Save.
+Changing the password for your Yahoo partner email account
Dec 13, 2013 | Computers & Internet
Changes password
If you need to change a password then there may be a option to change a password or forgot password. Click on one of those. If you choose change a password then you need to remember your old password if not you can go to forgot password and follow the instructions given. Usually they send a rest link or some activation code will be send to reset or change the password.
Thanks
Nov 04, 2013 | Computers & Internet
I have the first firefly phone from att&t then cincular i am needing to reset password and don't remember the code to do that.
For the Original Firefly Phone:
The default PIN is: 1 2 3 4.
For the glowPhone:
The default Password is: 0 0 0 0
When you first set up your password, you will be able to change from the 0 0 0 0 and enter your own.
If you should happen to forget what password you entered, you can enter the bypass password: 5 6 7 8 and this will then allow you to go into Parental Controls and change your password:
- Scroll to and select Permissions
- Scroll to and select Change Password
You will be prompted to enter a new password, then reaffirm it. You will get a confirmation when the password is successfully changed.
For the flyPhone:
The default password is: 1 2 3 4
When you first set up your password, you will be able to change from the 1 2 3 4 and enter you own.
If you should happen to forget what password you entered, you will need to follow these steps:
- Turn on your flyPhone
- From the Main Firefly Screen, you will need to type in the following (once you start typing, the screen will change): #20070330#
This will restore your flyPhone back to the default settings, so you can now go back in and reset your password.
or try this:
How can I change my phone's Password/PIN? For the Original Firefly Phone:
- Press and hold the green SEND button until you see ENTER PIN. Press Enter.
- Enter your PIN Number by scrolling though and accepting the four numbers you choose. (The default PIN is 1 2 3 4).
- Scroll to DONE and Press OK.
- If your PIN numbers are accepted, the display will say Change PIN.
- Press OK to let Firefly know that you do want to change that PIN.
When the display panel says SAVED, your new PIN is loaded.
For the glowPhone:
For the flyPhone:
Hope this helped.
Source: http://www.fireflymobile.com/
Jan 05, 2011 | FireFly Cellular Phone
How i transfer data from window to linux
Depending on your linux distrobution, you will need to check the /etc/samba or /etc/smb configuration file, within that file there will be a place to set your windowsfile sharing password. then you will be able to transfer data across the local network between your linux / windows machine again..
however, if you've actually changed the password for the linux user account that enabled the samba file sharing, you will need to either remember that password, or set a new one from the root account byt typing the following command in a terminal / bash / shell session:
Task: Set or change user password Type passwd command as follows>
$ passwd <user>
Output: Changing password for <user>
Enter new password:
Retype new password:
passwd: password updated successfully
NOTE: when typing the password, you may not see the password you are typing..
You need to replace <user> with the username you are changing the password for.
May 25, 2009 | Dell Dimension 1100 PC Desktop
CHANGE PASSWORD/ETHERNET ROUTER/WINDOWS VISTA
to make it clear..
change password meaning you need to update your router's password?
SOLUTION: access router's interface and enter correct password information
OR
change password meaning reset your password for your router?
SOLUTION: call router provider/manufacturer ISP to have router's password reset..
Jul 17, 2008 | Alcatel Speed Touch Home Modem
Open Questions:
Online backup and storage 'DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
May 25, 2018 | Quantum Computers & Internet
Computers & Internet Logo
David Payne
David Payne
