Question about Nikon Coolpix S210 Digital Camera
Lense won't open
What size philips screwdriver did you use to open the camera? i'll try to remember/document how to put it back together.
    Problem Solver:
  • 5 Answers
Stop! before you open the camera try gently knocking the corners to loosen any particles that may have gotten into the lens housing. It may start working. If you get it open spray compressed air to clean it out. Next camera just buy an extended warranty. I found www.northamericacoverage.com to offer reasonable priced extended coverage on all products. In general every digital camera I ever owned had problems after 1 1/2 years of usage. They don't made them as srurdy as the old film cameras.
Posted on Jul 21, 2009
LOOKING FOR A NEW DIGITAL CAMERA, WHICH ONE IS GOOD?
That depends on what features you consider important. How much does size and weight matter? Do you value ease of use over ease of learning? Do you want the versatility of interchangeable lenses or the convenience of having everything in a single package? Only YOU can answer these and other questions. That's why there are so many different digital cameras out there. The camera I use daily may not meet your needs at all, yet it's the best camera for MY needs.
You'll find many buyers' guides at the magazine rack of a good bookstore. You'll also find online reviews at places like here. Just remember that the best camera for you is the one that best meets your needs, not that of any reviewer.
Mar 09, 2012 | Cameras
I want to open the cannister to work on the cord rewinder but I don't want to force it and I am unable to locate/see how the back latches work.
This should really be done by an authorized Aerus Electrolux servich technician. I've seen quite a few dismantled machines come into the shop because the owner couldn't figure out how to put it back together properly. And the cordwinder can be even more difficult. The service techs really don't like to put together a dismantled machine.
There are no back latches.
However, to open the canister:
You will need a flathead screwdrive and a hammer.
1. Remove bag
2. Lay on one side, with bag door open all the way
3. Push tip of screwdriver in the back of side rubber strip.
4. Use hammer to hit screwdrive toward front of vacuum.
5. When strip is 5-6 inches out, grasp with fingers and and slide gently out the front of vacuum.
6. Repeat for other side.
7. Lay machine on it's top and lift bottom half of canister off top half.
8. You now have access to cordwinder. I suggest you take notes as you go so you remember where everything goes.
Putting it back together isn't this easy.
Nov 23, 2010 | Electrolux Lux 5500 Canister Vacuum
Zoom--mm blinking and can't change mode
Your zoom motor is probably stuck. Remove the two screws on the front side of the tiltable head. Pry off the two tilt caps using a small flat head screwdriver (they are glued on). Remove the 4 screws found under each cap. Now you can separate the two sides of the head and take out the two lenses (remember exactly how the lenses were positioned). Try pushing the flash in or out (it should move with a little force). See if the flash now responds before reassembling.
Mar 21, 2010 | Canon Speedlite 430EX TTL Flash
SONY DSC W35 "Access" "Turn the power off and on again"
Yes this can be cleaned with a can of compressed air. but I feel you went above the call of duty here to repair it yourself and I congradulate you for your go getter do it yourself attidude and action. Now you might have to chalk this thing up and get a new camera as once these are cracked open its done unless you now what exactly you are doing, its like a kid in a cookie jar effect..
Sep 23, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
When I turn on my DSC W55 the lens does not open all the way. Is better to fix it or buy a new camera?
It usually cost more to repair digital cameras than investing in a brand new one. Before you decide to trash your camera and buy a new one try this.
Some dirt somhow gets on the outside of the lense and they would prevent the lense from opening or closing 100% as it normally does.
Clean around the lense and turn your camera off and on a few times. If the lense opened out 100%, you should be able to take pictures as you usually did. If NOT
turn on the camera and help the lense to open up by pulling the lense out NOT too hard. If the lense goes up and down you follow the lense motion (up and down and turn). If the lense opened up 100%, then turn the camera on and off a few times, it may work now.
If you have dropped the camera, some mechanical part of the lense mechanism is broken or disslocated. In that case, the lense has to be opend from the camera, inspect for broken parts or loose parts, and clean it up. If you put it back on the camera, it may work. Remember opening the lense is the absolute last thing you want to do. Most likely, you would make it worse than, before opening it.
If you decided to buy a new one and trash this camera, please send the camera to me. I will pay to you ONLY your shipping cost. I would try to fix it and learn more about the problem your lense have. I would be able to help the next person with the same problem better. my email address pourmp@yahoo.com.
GOOD LUCK !!!!!!!!!!!
Jun 15, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot 7.2 went to shut off camera and lense is still out no power to camera tried to recharge batt. w/no results
Try different batteries. I got the same problem with my cyber-shot. The battery was too low while lense was fully open. I recharged, but the lense would not close. When I turn it on, It would say turn off and on again. I did that for at least 20 times. I finally put another set of batteries and while I turned off the camera, I pressed the lense in very softly. After a couple of times the lense retracted fully. The camera has been working normally ever since.
It is also possible some dirt some how got on the sides of your lense. Try cleaning the sides of the lense.
If you had no luck so far, then your lense may have some mechanical problem. The lense need to be opened and cleaned and put back together.
good luck
Jun 09, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
Jammed lens
When you turn it off, does the lense go up and down. If yes good news. while turning the camera off press on the lense very softly (up and down motion) until the lense retracts 100% or almost 100%. you may have to try a few times. if almost 100% retracted, push the lense a little harder in, untill it retracts all the way in. Turn it back on, it should work now. If you do not keep your lense clean you get that problem. After you droped it, some mechanical part on the lense may have broken or dislocated. In this case you have to open the lense inspect the parts, clean them and puth them back together.
Jun 08, 2009 | Polaroid i830 Digital Camera
Camera lense
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
May 05, 2008 | Minolta Vectis 2000 APS APS Point and...
Retractable Lense Does Not Open
This thread might be relevant to your problem: http://www.fixya.com/problems-solutions/t114846,p220455/Olympus-Digital-Cameras.aspx Comment on what you saw in there when you opened it up, compared to the other user. Good luck
Jun 21, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
My digital Sony camera fell down Lens got stuck
Hello, Im "Darntoothysam" and heres how to fix it for FREE, but ONLY if your lens is stuck at an angle. Heres a trick for you, you might be able to fix it yourself. With the lens pointing perpendicular to the ground, place the edge of the lens on the edge of a table or counter. NOT the flat round front section of the lens, the curved edge or side only. Position the lens on the table and press on it so that you are pushing the lens back towards the center to straighten it out. You may need to press slightly hard, don't worry, its already damaged so youre not going to hurt it if you don't push with all your might! Keep pressing on the lens, if it doesn't pop back in push slightly harder. This will either work, or it wont, like I said, just don't put all your weight on it. If it pops back in place, it will probably work just fine again!
May 02, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
154 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
