Nexttab new and has thermal shutdowns too frequently
2 Suggested Answers
gusgub
  • 16 Answers
SOURCE: Frequent thermal shutdown when viewing
This is most likely because of a blocked/ dusty fan, worn out thermal paste, broken temperature sensor or a failed fan. This is a common problem among HP laptops.
Try taking the machine to a trusted repair center and explain the problem. They will be able to open the machine, inspect for faults and clean the cooling system and replace parts as necessary. Because this problem includes moving parts it is most likely not covered by warranty.
If you are confident enough to open the machine and carry out the repair yourself, try using the technical repair manual on the link below to help you.
http://www.hp.com/ctg/Manual/c00212209.pdf
Hope this helps!
Posted on Aug 19, 2011
What is thermal shutdown ? And how do I fix it? I bought it less then 30days ago.
Thermal shutdown means what you bought overheated ! Take it back! hope this helped!
Sep 26, 2016 | Computers & Internet
Cordless 58v new chain saw cuts out frequently. restarts after a minute. Does this even when minimal cutting
Sounds like there is a thermal shutdown switch on the motor that is a bit finicky. New saw... maybe exchange it for another
Oct 24, 2015 | Echo Garden
How can I fix thermal shutdown of Acer b1-730?
Could be the CPU needs new thermal paste and reseating.this is usually a fail safe designed to protect the computer when the CPU is getting too hot.also check the cooling fan ......blocked vents as this may also cause overheating issues thus not cooling the internals which will activate thermal shutdown.
Mar 18, 2015 | Acer Computers & Internet
Unexpected shutdown. my computer turns off. it has 100% battery remaining. what is the problem? how to fix it?
how old is your computer?usually the trouble of your computer is in the cooling system..you must clean the path ways of the exhaust of the cooling module and put a new thermal paste on the processor that causes the machine to shutdown by detecting an overheat on the processor,it shutdown automatically to prevent damage to the main board that cause by overheating...kenthbats
Jun 07, 2010 | Computers & Internet
Hp laptop random shutdown - overheat?
Your CPU is likely overheating. Very likely the thermal conducting material between the CPU chip and the heatsink may have shrunk and now impeades the thermal transfer.
You may need to remove the heatsink and put new thermal paste and perhaps copper shim to restore the thermal contact to the heatsink.
Jan 04, 2009 | Everex StepNote XT5000T Notebook
System crashes frequently after got the board repaired
hi dude,
          better format d old windows and install new windows...my frend had a similar shut down problem, by formatting and installing new windows, solved it...dis can solve ur problem
                                                good luck,
                                                trendsetter
Jul 03, 2008 | Intel D845GVSR Motherboard
Computer is switching of frequently
Try changing the cmos battery on the motherboard.
OR your PC could be overheating,check your bios to see if the thermal shutdown temperature is set too low.(assuming you can get into the bios)
Recommend new thermal paste on cpu,ensure fan/s are working.
Apr 21, 2008 | Computers & Internet
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
