Question about The Optics
How can I increase the power output on my Hatsan Herculean pop Air Rifle
How do tighten / secure the barrel to the stock of my Beeman air rifle R9
It is a break barrel and if you secure it to the stock how will you cock it
Sep 07, 2014 | Beeman R9 Air Rifle, No Sights - 0.177...
How do I tighten/ secure the barrel to the stock of my Beeman R9?
Has the stock dried out or the stock screws coming loose
Has the stock to action gap gotten larger if so you could try getting the synthetic stock
How do I tighten the barrel to the stock of my Beeman R9?
You cannot as the barrel is attached to the compression tube by the pivot bolt and the tube is bolted to the stock by one bolt on each side of the forend and two on the trigger shoe
So what you can do is either hydrate the stock or bed the action to the stock to take up the looseness bedding the action would be the better option
How to increase power to my daystate mk3 air rifle
Get a new air rifle with more power?
Dec 29, 2013 | Optics
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
V-fit herculean cross trainer assembly instructions
assembly of the wires for v-fit herculean cross trainer
Jun 21, 2010 | Body Solid G9S Multi-Station Gym
Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Jun 01, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Optics Logo
24 people viewed this question
Top The Optics Experts
David Clark
David Clark
Lawrence Oravetz
Are you a The Optic Expert? Answer questions, earn points and help others
