No audio output to hook up sound bar - Televison & Video
  • Televison & ... Master
  • 6,694 Answers
Checke the video
How to Connect Soundbar to TV audio
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 26, 2016
Model 3707. Sylvania model sb377w sound bar. Why is there no sound from the sound bar when connected with the a/v ports?
If you are hooking to the av ports on the TV then you need to make sure first that you are on the audio outputs. Second you need to go into the TV audio menu and turn on external speakers. If you do not want to do that then you can hook the audio directly to the source. (the cable box audio out). That will get you what you need.
Dec 30, 2015 | Philips Televison & Video
Hook up samsung sound bar to lg smart tv
easiest way would be to connect the optical audio output from the tv to the optical input on the soundbar. You may have to go into the tv's setup menu and enable the audio output jack
May 10, 2014 | Samsung HW-D450 Sound Bar
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
How to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
Jul 24, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
How do i hook up my sound bar to my tv
Unless you have audio output on the TV, then you can't. You will need to run the audio from a cable or Sat box to the sound bar unstead.
Apr 10, 2012 | Televison & Video
I lost my instructions for hooking my sound bar up to my new tv I ahd it hooked up to the last one and it worked now no sound and when I raise the volume it doesnt do a thing I programmed it to with m
Some sound bars have a seperate power cord, did you plug it in. Also, the source for the sound, are you using the audio outputs and not the audio inputs. They are all the same color (red and white) so you may have plugged in the wrong ones. If the sound bar is getting power, say a green led and the source for it is the tvs audio ouput jacks you might have to see if there is a seperate remote for the sound bar and raise the volume. Lastly the tvs audio output might have a seperate setting, it could be fixed or variable. Fixed will only change volume with the sound bar remote. In variable you will be able to change the volume with the tv remote but first you have to raise the sound bar level. Hope this helps in some way.
Feb 26, 2012 | Televison & Video
How to hook up a sound bar to this tv
I don't see any audio outputs on this television. Without them it is not possible to connect a sound bar. However I am currently using a sound bar with a television with no audio outputs. I am connecting my devices to the television with the video cables only and connecting the audio cables directly from them to the sound bar. I am pleased with how doing this turned out.
Aug 14, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I don't get sound from Vizio Sound Bar, need connection instructions.
You have a red and white composite audio cable the simplest way is to hook that to your audio output on your tv then obviously the other end goes into the soundbar. Make sure its an OUTPUT not input on the tv, if you hook it up this way everything that plays on your tv will then play through the soundbar.Some tv's do not have an audio output if this is the case then you will have to hook it up to an output of another source such as DVD player or cable box. There are two other possible audio outs on your tv they are fiber optic audio and digital coaxil audio but usually not the case as they are usually only inputs. One other thing some tv's(very rare) require you to go to menu to enable audio out. There is one other possibity and that is HDMI which carries picture and sound but again TV's rarely have this output.
Dec 13, 2010 | Vizio Televison & Video
How do you hook up a sound bar too a westinghouse TV
Usually on newer westinghouse tv's the only audio output on the tv is the headphone jack so you will need to buy a 3.5 mm stereo to rca converter and use that instead of the rca cables provided with the sound bar.
Jun 12, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
