Question about Music
Need to hook up elkavox accordion to generator to midi unit
Best way to connect two electronic drum modules together
use one MIDI cable connected to MIDI Thru jack
Jun 17, 2012 | Roland Music
How do you get sound coming from the keyboard without an amplifier?
You don't... in two words... this unit is NOT intended to generate sound without and external generator and amplifier... or you can use the puny sound generation in a connected PC.
I've initialized it and now have lost the preset patterns, Is there any way I can get them back please? - CHRIS
I assume you held the erase and play and re-initialized the firmware. I assume you failed to generate either a backup MIDI file or an audio tape backup. Now you will need to find another person with an SR16 and copy via MIDI or Audio (really digital) tape to reload your unit. Your user manual will tell you the procedure to do this once you find a host SR16.
Aug 04, 2011 | Alesis Sr 16 Stereo Drum Machine
I have a 3rd generation m-audio midi keyboard, when i switch it on the numbers keep on rolling.
See if the buttons that scroll the numbers MIGHT be stuck down. Try wiggling them sideways and see if it stops. Beyond this you will need to open the unit and inspect for possible cable problem or debris that might be shorting the signals from the panel buttons.
May 03, 2011 | M-Audio Oxygen 49 USB Midi Controller
I plug two roland pk-5a to have 1 octave above the other one but the problem is I can't play in the BASS MODE or MONO MODE with the HOLD function on and stop the note I play on one unit when i play a note...
If you have two MIDI sources that you send on the same MIDI or to the same MIDI sound generator you have to use a "MIDI MERGER" or you will get notes stuck on. A MIDI merger assembles complete messages before sending them to their destination. Without it, the messages are mixed which makes them garbled.
Mar 24, 2011 | Roland PK5A MIDI Controller
I have just bought a second hand Evolution MK-161 MIDI controller music keyboard on ebay. It works fine when I play it through my computer using the virtual organ software 'Hauptwerk' (which is the prime...
You must use some form of MIDI sound generator module connected to get sound... It is a standalone capable MIDI generator, but NOT generating audio.
Mar 01, 2011 | Music
I can't get my Yamaha WX5 to sustain, or play more than one note. I got it to do it long ago by accident, but can't seem to get it to do it again. I think I was using a Yamaha Keyboard for the sounds at...
Reread your manual pages 14 and 15. Note page 14 tells you that "When using a monophonic tone generator such as the VL70m, the Normal Hold and Follow Hold functions CANNOT be used." I have both the WX5 and WX7. I also have both the VL70m and the WT11. The VL70m has a lot of better sounds, is editable and has better effects the WT11 allows you to use both follow modes. Any polyphonic midi keyboard with a midi in jack will allow you to use the follow modes. Read the directions on page 9 of your WX5 manual to hook your WX5 to the keyboard. Set your keyboard to receive all midi channels. I think it is Omni On, Poly. Hope this helps.
Nov 06, 2010 | Yamaha WX5 Midi Wind Controller
Hooking up two roland brain modules.
No need to connect via MIDI. Just connect the pads to whichever and run audio out of each into seperate mixer input.
Unless you were going to use built in rhythms there is no real need to synchronize the units.
Apr 25, 2010 | Music
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Music Logo
22 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
