Question about Protocol Manta 4-Channel Radio-Controlled Quad-Copter
When going through set up, sliding left controller from bottom to top, the unit wants to lift off rather than wait for full procedure to be finished.
When going from bottom to top the unit lifts off and controller cannot be put in neutral position as this will cause the unit to lift off.
Ford focus front strut replacement
basically remove the wheel ( after placing the vehicle on jack stands). remove the bottom ball joint connection ( bolts or ball joint with a ball joint splitter) use 2 spring compressors and close up the spring mark one bolt in the engine bay at the top of the strut so you know where the unit goes on reassembly The bolts control the wheel alignment)undo the bolts and drop the unit out the bottom. undo the nut at the top and release the spring clamps. Lift the spring and top plate of the shaft. Undo the insert nut and remove out of the tube. Insert new insert and reverse the procedure. A workshop manual ( genuine or after market will have the procedure in full with photos)
Jul 25, 2014 | 2000 Ford Focus
How do you open up a Sony rm-gd008 remote for cleaning?
  1. Maybe worth a shot, carefully thou
  2. Remove 2 * screws under battery cover
  3. front of remote: slide down the bottom cover (where rec, pause, etc option is)
  4. push both egdes of the slide area outwards, to totally remove this slide cover
  5. further more, now push both the above slide edges even more .. till bottom of (front face) cover loosens up. Whilst lifting this only a little at a time ...
  6. Gently remove /loosens only lower ends (only at this stage) of the 2 silver edge stripes... by .. lifting up (away from face of remote) ..whilst .. moving them outwards. ** i.e up, then outwards) Do not remove top edge of silver tip yet
  7. start separating left n right egdes with sharp flat point from under silver side strip, " digging" downwards towards bottom of remote
  8. At this point, the top edge of remote may be separated, but not necessary.. if you can pull insides out from bottom, PREFFERED OR .. can be done by:
  9. using flat edge - loosen/pry 1cm from corner on top tip of edge left n right digging downwards n outwards towards bottom of remote .. enough gap to use a little pressure if you must
  10. then if feasible, separate remote face .. also 1cm from right n left corner alongst each side from top corner
  11. .. now can remove silver side strip completey.
  12. Hope this helps, cheers
Dec 04, 2012 | Televison & Video
The dehumidifier does not shut off when the resevoir is full and therefore over can I fix this
Turn the unit OFF and unplug it from the wall. Remove the bucket and empty any water that may be in it. Then, look at the top of the bucket for a float valve control. It slides from left to right, depending on whether you want it to shut off at half full or three quarters full. Slide the float left until it snaps for 3/4 full or all the way to the right until it snaps for 1/2 full. The bucket must be properly aligned for the float to work.
In your case, the float may have moved to the middle. Or the bucket is not squarely into it's holder, from top to bottom.
Troubleshooting the above should solve the problem.
Jul 08, 2011 | Whirlpool AD75U Dehumidifier
Changing ink instructions canon MP240
With the printer on, open the paper output tray. Then lift up the scanner unit (with the document cover closed). Make sure the support is holding the scanner unit. Then wait until the cartridges move to the replacement area. Pinch the tabs together to open the cartridge locking cover (it just rotates up). Then remove the cartridge by pulling it towards you. Prepare the new cartridge - remove it from the box and remove the orange tape. Do not touch the electrical contacts or the print nozzles.
Slide the new cartridge into the cartridge slot (color on the left). Then close the locking cover - it should click into place. Make sure the cover is correctly closed. Lift the scanner unit to disengage the support and lower the scanner to close it. Wait for the printer to clean the new print heads before sending a new job to the printer. (It will finish printing a job that was in progress when the ink ran out.)
Note: if the scanner unit is open for too long, the cartridges will move to their home position. Close the scanner unit and reopen it.
You can find pictures of the procedure at Canon's support site: . Searach for replace ink cartridge. Altternatively, go to the Brochures and Manuals page and see the manual.
I hope this helps.
Mar 08, 2011 | Canon PIXMA MP240 All-In-One InkJet...
It is not really a problem. I am wondering if I want to transport our stackable washer/dryer ...(moving it to our cottage) can it be flpped on its side? or will this do it some damage? Can it be taken...
Good Morning; Thanks for your question. The easiest way to move and transport your unit, is to separate them. Go around back of the unit. Where the top unit sits on the bottom, there are two lockdown brackets, one on the right and one on the left. Remove and save. Slide top unit back until front feet are released from front brackets. Then you can lift off. Note, it probably will take two of you for the lifting. It is best, that you not lay them on their sides. Hope this helps and have a good day.
Jan 28, 2011 | Kenmore 98702 Stacked Washer/Dryer
I get the F 11 error code on my whirpool duet and then cannot unlock the door. I can get error code to go away, but cannot get the cycle to finish, or a new cycle to start or the door to unlock. My clothes...
The error code F11 means serial communication error between the central control unit (CCU) and the motor control unit (MCU). Either the CCU or the MCU is faulty, but the door lock mechanism is controlled by the CCU and the jamming of the door lock points to the CCU being the culprit. Replace the central control unit (part number 1176592) to fix the problem.
Central Control Unit Replacement Procedure
  1. Remove the three screws at the rear of the machine securing the top panel.
  2. Slide back the top panel then lift it off the machine.
  3. Lift the top plastic tabs of the central control unit (CCU) that are securing it to the back cabinet frame.
  4. Slide the CCU towards the front of the machine and remove it.
  5. Disconnect the wiring harness connectors from the CCU. Make sure to take note the positions of the connectors.
  6. Connect the wiring harness connectors properly to the new CCU.
  7. Reinstall the CCU in reverse order of the above procedure.
  8. Reinstall the top panel before performing a test run or running the machine.
Manual Door Unlocking Procedure
  1. Lean the washer on its back against the wall.
  2. Remove the lower toe panel by removing the three screws under the bottom edge on the front of the washer.
  3. Reach up along the inside of the right side of the front panel and locate the tear-drop shaped tab and gently pull it down until a click is heard.
  4. You can now open the door.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sometimes washer stops and gives f 11 i hit pause then start to finish load
F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
In your case, the problem is intermittent and it may indicate a glitch in the wiring harness connection between the MCU, CCU and the motor. The glitch may be due to a loose, soiled or oxidized terminal connection. Check and clean the terminals and connectors.
  1. Remove the three screws securing the top panel at the rear of the machine.
  5. Disconnect and clean the terminals and connectors one at a time.
  6. Reconnect the connectors properly and ensure a good connection with the terminals.
  7. Reinstall the CCU in reverse order of the above-mentioned procedure.
Access to the motor control unit (MCU) requires disassembly of the machine's front panel. Please let me know if the error code still appear and if you need to access the MCU and the motor.
Jan 14, 2010 | Kenmore Washing Machines
Locked out of vehicle Broke out sliding center section
Put the top part first, and the lift it until you can put the lower part in and lower it.
Mar 29, 2009 | 2005 Dodge Ram 2500 Truck
Removing top component
kenmore washer
remove left right edge trims of control panel
remove phillips screws from bottom edges of control panel
slide control panel forwad and up ~1inch
flip control panel over the back
remove bronze body springs
remove lid switch connector
lift body ~1inch slide forward and off
reinstall in reverse order
Aug 10, 2008 | Kenmore Oasis HE 27082 Top Load Washer
How to remove the battery
Have to completlydissaemble unit. Not hard but fiddley and tiny parts. Remove top custom color plate with fingernail. remove 2
phillips screws and set aside on nonslip surface (tissue). slide top plate with view screen away form usb connector 1/16 inch to unclip and lift off. Slide Metal belt clip left or towards usb port side (carful not to scratch ld viewscreen. and set aside. Remove 2 philips screws holding circut board and lcd (Set aside seperat from other screws as shorter and must go back samme place.
Fingernail out whit clip over usb port and set aside. Lift entire circutboard/lcd unit on left side (usb port) up and slde out that end so as not to catch volume control . Carful of battery leads.
Raise far enough to get fingernails on battery terminal clip ON BOTTOM OF CIRCUT BOARD and pull straight off. ( note polarity as clip will fit back on either way but only 1 works and reverse polarity may damage unit. Wafer battery will pull right out of case and haspolarity +/- marked with numbers (assume model or part number)
Feb 22, 2008 | Samsung Yepp YP-F1Z MP3 Player
Protocol Manta 4-Channel Radio-Controlled Quad-Copter Logo
Top Protocol Toys Experts
Level 1 Expert
Are you a Protocol Toy Expert? Answer questions, earn points and help others
