Question about Thermador Ovens
How to turn on old Thermador oven - Thermador Ovens
2 Suggested Answers
SOURCE: thermador oven parts
I have a Thermador oven where the inside window glass is broken. Are there any parts available for a
model #14-33-754
30 "?
kellythompson@frontiernet.net
Posted on Nov 22, 2010
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
I need a replacement selector switch for an electric oven. It it for an old Thermador electric oven (one cavity type wall oven). Model number: WO-18A
Hello & Welcome to FixYa
You can buy it from here. Please get back to me if you have any other questions.
Kevin
Sep 13, 2011 | Thermador Ovens
Thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
Sep 11, 2009 | Thermador SMW272 Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Thermador SCD272 Panel Dimm Problem
a phone call to thermadore is definatly an option open to you, im sure they will handle you situation as do all manufactures on a case by case basis, at only 2 yrs old you may even fall under a part warr from them,not to mention as you explain to them how you see the amount of others with hte same issue, is quite possible they offer you a concession, worth the 800 number call and the 20min time to do it
Nov 03, 2008 | Thermador SMW272 Electric Double Oven
Thermador oven parts
model #14-33-754
30 "?
Oct 23, 2008 | Thermador Ovens
Thermador CMT227N
Hello air pro AC,
Welcome
You said, In the microwave mode - immediate clicking noise at start up. Oven, Convect modes work
Oh there are many things to check here.
1.look at the wheel base turning the plate that rotates your food for crumbs or sticking pieces of food.
2.check that the wheels are not worn down.
3.There can be a problem in the bearing, or linkage, or motor that spins the plate!
Do you get a error code?
How old is it ?
huuum
Waiting your response!
Oct 17, 2008 | Thermador Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Ovens Logo
29 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
