Question about Radio Communications
I just received an s107g. I've followed the instructions but there is a light flashing red in the nose and the throtle works very intermitantly
4 Suggested Answers
  • 3 Answers
SOURCE: screen wont turn on - flashing green light
hello mark ,just had the same problem with my pioneer pdp503 hde, fixed myself and very easy to do. its the power supply board ,got mine on ebay for 109 pounds.was very easy to is the big silver panel in the center just unscrew and disconnect cabels. very commen problem in pdp . mark doran post again if you want more info
Posted on Jan 23, 2008
SOURCE: i just recieved my s107g
You have to charge it up through the USB cord or the cord built into the controller. It's in the "crappy" instructions, so you clearly didn't RTFM.
Posted on Feb 17, 2011
SOURCE: my syma s107g gives a
fully charge your heli----turn on transmitter-wait 2 seconds-turn on heli
wait for blinking green led to stop blinking-turns steady.....rev up
with a quick full throttle and back to idle--happy flying
Posted on Apr 21, 2011
Remote not working
I would suspect a fault but check the batteries in the remote are fitted
Jan 28, 2014 | Syma GIFT SET 2 S107G R/C Helicopters Blue...
I have a Genie Directlift 2060 garage opener. My wireless keypad has always worked fine until now. I enter the code and nothing happens. I replaced the battery with the same result. I followed the...
Your wireless keypad may be flashing the red light to falsely assure you that it is working when, in fact, it is not. Another possibility is that the receiver has failed.
Oct 21, 2013 | Sears Craftsman LiftMaster Chamberlain...
My S107g wont respond to the transmitter
I have the same problem, worked twice with a steady red light but then back to flashing and no comms. Turned all the TV's and wireless network off to see if this would help but still no joy. Need a solution as these are really cool little toys !
Nov 24, 2012 | SYMA Toys industrial New Syma S107 Radio...
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
TV not working
The red light flashing is an error code. Count the number of flashes before a long pause.
Mar 22, 2010 | Samsung Electronics - Others
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
Tv turns on briefly then goes out with red flashing status light
This is exactly intermitent problem, It needs to be trouble shoot at the repair shop if the problems occurs from power supply or high voltage.It needs a lot of test and equuipement to be accurate.And also the specific parts.
Nov 28, 2008 | Mitsubishi Televison & Video
Radio Communications Logo
44 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
