Question about Cannon Office Equipment & Supplies
My cannon isnt pulling through it keeps saying load papers
MI bought used cannon mx 300 I think there something might be missing how do I load the paper pictures please so ican see
SOURCE: Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Posted on Sep 07, 2008
SOURCE: HP Officejet 7410 AIO keeps saying out of paper when plenty of paper loaded
I have the same unit. There are many issues with it. First when you install the software you may need to add something to the registry.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Print\Printers\HP Officejet 7400 series\PrinterDriverData and create Key HPDJEnableSecondTray as DWORD with Value of 1
Once you've done this here is the biggest issue and one I've found to fix this issue PERIOD.
You need to go to your Printer Driver then to Properties of it then Device Settings Tab - you will see Form to Tray Assignment in the list and like 5 options, you have to make all but the one you want to NOT AVAILABLE. Example mine is set to Upper than Lower (Letter) all the rest are set to NOT AVAILABLE. Problem solved.
Posted on Apr 15, 2009
  • 14 Answers
SOURCE: "Load Paper" screen wont go away. Is loaded with paper!! Help!!
Goto the job status and select the print job that is waiting.. To the right, select details and select the paper size you want. Identify the job because you will want to make sure the settings in that document are set to the correct paper size and type.
Posted on May 01, 2009
SOURCE: samsung clp-300 Paper feed problem.
I was having the same issue with premium paper. It wouldn't take it, but it did okay with paper of less quality because it was rougher. Here is my solution.
Unplug your printer and remove the paper feeder tray. Flip the printer on its side and underneath, you will see a rubber piece that feeds the paper through the machine. Wipe it down thoroughly with rubbing alcohol on a cotton disc or ball. You should get a bunch of brownish grime coming off on the little rubber dealy. Blow dry, plug in, and you're good to go. Just did big print job to test. Good luck!
Posted on Jan 10, 2010
The problem is normally on the exit sensor.Please check the exit sensor if its in the right possition.If the exit sensor is in the right position,also check the registration sensor if its sitting in the right position.Normally the problem is that the sensors (either the 'exit ' or 'registration' sensors) will be not in their correct position.If the two sensors are ok,there should be a small paper lleft in the machine
Posted on Apr 17, 2010
I have a cannon pixma mx 300 all in one.Wheh I try to print, the paper wont go through the feeder. Is there any way that I can solve this problem without calling an expert
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 24, 2009 | Canon PIXMA MX300 All-in-One Printer
My cannon printer keeps saying alarm 32 what does this mean
You may have to open and shut a door to make it reset. There is a sensor detecting something or claiming too. The paper tends to load on the right side and not the left. The paper goes in sideways and therefore jams. This seems to be a common complaint with this printer.
Sep 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MX 700. I cannot get print alignment. I am missing lines. Have done head alignment 20 times and still cannon resolve issue. Have replace cartridges, cleaned heads, rollers, deep clean and still no...
My MX700 is 1 year old and I to have issues:
1) Alignment
2) Says it's out of paper when there is paper in it. Shutting off an Turning on usually helps
3) Feeds multiple pieces of paper at once!
Aug 30, 2009 | Canon MX700 Office All-In-One InkJet...
Cannon MX700 Output is blurred
You will have to replace the print heads on this printer. They most probably got damaged when you pulled out the paper jam.
Aug 12, 2009 | Office Equipment & Supplies
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Samsung CLP-315 paper tray position
There is absolutely nothing wrong with your printer. The tray is recessed during packing to reduce packing space for shipping. When you pull out your paper tray for use for the first time it expands to accommodate the paper. It can be collapsed by pushing the little blue tabs that say press here to make it flush again but you would only need to do this if you were using a non standard paper size.
Jan 02, 2009 | Samsung CLP 300 Laser Printer
Cannon mp780 paper pulls to right hand side and jams everry time
printer loading tray have problem /something struck at left side of tray /check if something/if none / sometime it connot be seen its hide five cents .
clean also the incoming roller and outgoing rooler w/cotton tips w/ rubbing alcohol. test the printer.
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
22 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
