Question about Panasonic TC-P50GT30 50" 3D Plasma HDTV - 1080p
I have a Panasonic TC-P50GT30 it has a 14 blink error code. I have replaced the power supply (online suggestion) no change. I followed the you tube video for checking the boards no shorts. What next?
The video now suggests replacing the A board.I don"t want to keep replacing all the boards one by one.
SOURCE: power board
yes your sc board is short you must also do a firmware update
Posted on Dec 17, 2010
welcomejee
  • 10594 Answers
SOURCE: Pana TC-50PX14 dead set with
Blinking light indicates that tv went on protection mode due to internal problem and 7 times blinking is an error code that shows problem with SU, SD, SC boards in Panasonic TC-50PX14 plasma tv.
Below is an image of boards location in tv, taken from service manual, above said boards have been marked for convenience.
Let me know if you have additional question.
Thanks.
Posted on Dec 27, 2010
ladywinn
  • 5138 Answers
SOURCE: My tc-46pgt24 blinking 10 times and I already
Look for open Fuse and Bad Capacitor it will be swollen or vented on Top. 14.86v is normal
Posted on Oct 18, 2011
gopakumarg43
  • 75157 Answers
SOURCE: I need help changed power supply board and ss board and still no picture it is a model TC-42PX14 panasonic the red light still blinks seven times. At wit s end isn't much, can you help me.t
Check this link and select the site named 'Electro-help' You can get more details about the fault to your TV, with 7 blinks of standby light. Check this link and select the site named above.
Posted on Jul 28, 2012
  • 127 Answers
SOURCE: my panasonic TC-P50S30 will not power up what can I do?
Change the fuses or the power suply module.
Posted on Nov 02, 2012
My panasonic Viera tc-p60gt30 has 11 blinking LED error code this TV does not have a fan. Could it be the power supply? Is there a place to plug in a fan to solve the error code?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 24, 2015 | Panasonic Televison & Video
How do I fix my Panasonic Plasma TV?
Call in a repair specialist. You have done everything you can do.
Nov 18, 2015 | Panasonic Viera TC-P50S2 50" Plasma TV
Panasonic Plasma TC-P42C1 10 light blink code, then the light came on and then no light at all-nothing! Power Suppy board?
By blinking led its shows where is exactly the complaint. You have to count the blinking. How much time its blinks in one sequence. the only it will be possible to say is it power supply or any other boards.
www.electro-medical.blogspot.com
Sep 03, 2015 | Panasonic Televison & Video
I have a Panasonic Plasma TV Model TC-P55GT31. I got the 7 blinks of ***** and the TV is dead. Research online suggests it is likely the SC board.
Jul 17, 2015 | Panasonic Televison & Video
TC-P54G25 Won't turn on, 10 blinks. Unplug SC board, 6 blinks.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Jan 29, 2015 | Panasonic Viera Tc-p50c2 50-inch Class...
TC-P42ST30 power light blinks twice,replaced power supply board,no change.What to replace next?
Are you SURE you get 2 blinks? I show NO 2 blink code in the 011 model Pana plasma sets. Anyway...if you replaced the PS board and still get a code, unload the VS supply from the SC board and re-check--see if the VS supply comes up--even for a couple of seconds...about 205 volts or so. If it does--re-connect and see if it then does not come up. If not--then the SC board is likely bad (THE most common failure on ANY plasma set is the Scan board ).
Nov 24, 2014 | Panasonic VIERA TC-P42ST30 42-Inch 1080p...
Panasonic TC-P50G25 sudenly stopped working the Red light flashes for 7 times and takes a pause, this continues
Its an error code that likely indicates a power supply problem.
Suggest you Google the model number with "7 blinks" "error codes" or "service manual".
May 04, 2012 | Televison & Video
I have panasonic tc-p58v10 and it blinking 11 times. So my question is what is the problem and can I fix it with calling the repair guys???
Hi Frank,
11 blinks on Panasonic TC-P58V10 will be encountered once faulty fan(s) is/are detected upon self check. You have to double check the error code, let the unit unplug from the AC source (outlet) for at least one hour and check if the error code still 11 blinks, if so, I would advice you to check which fan(s) will not spin at the rear panel upon powering on the unit. If you've found a faulty fan, you have to replaced it with new one to resume it's operation.
Please let me know if you need further assistance.
Have a great day and good luck!
Jdvillanueva
Feb 18, 2012 | Panasonic Televison & Video
Tv turns on for two seconds, shuts off, begins binking.
The problem is most likely a power supply related problem.
The TV is in protection mode right now. It's keeping the other parts inside the TV from being damaged by automatically turning itself OFF. The 9 blinks should be an error code for the problem with the power supply. I don't have the Service Manual for your TV model number to tell you what the code means and which part to replace. Every brand of TVs have a different meanings of the code.
If you have electronic experience, you can find a factory repair manual over the internet. Normally, it's called a Service Manual. It costs about less than $20.
Jul 31, 2009 | Panasonic TC-26LX70 26 in. LCD Television
Panasonic TC-P50GT30 50" 3D Plasma HDTV - 1080p Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
