Question about Samsung Televison & Video
50 Inch Samsung plasma tv model # PN50A450P1DXZA none of the HDMI ports will work. It tells me no signal though it sees which HDMI port I have plugged into.
I have tried several devices and several HDMI cords which I have plugged into a different tv so I know they work.
  • 93 Answers
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Posted on Nov 06, 2008
SOURCE: hd tv doesn't work at all says invalid format
is the tv 720 or 1080. it wont work if your inputing 1080p to 720p or 1080i
Posted on Dec 24, 2008
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
SOURCE: All of the HDMI ports on my JVC lcd tv are not working.
I had the same problem on mine. It is a factory defect. It means your HD box that controls HDMI, USB, and RED GREEN BLUE component. Usually the red, green, blue, (720 HD) component is still functional, but the HDMI and USB are shot and can only be replaced not repaired. If your warranty is still valid and you have your receipt call JVC and they will give you the number to a certified warranty repairman. If you do not have the receipt they will not fix it. If you do not have the warranty and decide to repair it yourself or send it out, the fix is not difficult but it is costly. The box is about $1000.00 and the labor varies. The last option is to sell it for parts. If you decide to do this I will purchase the broken television from you. But if you have your warranty info there is nothing to worry about.
Posted on Aug 02, 2009
sabreusa
  • 271 Answers
SOURCE: HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Posted on Nov 09, 2009
Samsung PN43F4500AFXZA HDMI FIX
make sure you have it set to hdmi when cable is connected to source. try another working hdmi cable. try other hdmi ports.
May 08, 2017 | Samsung Televison & Video
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
How do set the resolution on a samsung 50" plasma (ps50q7hx)
make sure that the tv is in "HDMI" mode. If there are multiple HDMI ports on your tv then check to see which one it is. You should see HDMI 1, HDMI 2, etc. Then when you are sure what port it is in on either your tv directly or using the remote press the input button until the desired input is selected. So for example, if you have it in HDMI port one, press the INPUT button on either your tv or remote and cycle up or down until you select HDMI 1 and that should do it! sorry if it doesn't!
Dec 13, 2012 | Samsung Televison & Video
1 vertical black line on samsung plasma tv on left side (model # pn50a450p1dxza)
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
Aug 19, 2012 | Samsung Pn50a450 Pn50a450p1dxza 50" 720p...
How do i connect my Samsung plasma tv to my Compaq Presario SR1601NX?
Hi Prissy,
You get USB to HDMI/DVI cables with which you can make the connection with your TV to PC
Hope this helps you.
Regards
Nat
Jun 29, 2012 | Samsung PN50C450 50 inch Series 4 720p...
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
Broken HDMI Port for HP-R5072
The HDMI input along with others is located on the a/v control panel of which would have to be replaced. I haven't seen an input jack yet with a part number attached for any model. I would suggest call a service center for a diagnosis.
Jan 24, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Device code
some older cable remotes do not have the new lcd /plasm tv codes, you should consult with some one at the cable company and see if they have a box with remote that will support your tv.
May 27, 2008 | Samsung HP-T5064 50 in. Plasma HDTV
Televison & Video Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
