Question about Sony Video Cameras
I have a Sony DCR-PC1E and many DVM60 tapes. I should copy these tapes to my PC. Is a FireWire cable a possibility. Is this cable comparable to VMC-2DV/4DV as in the manual of the camera?
silly girl
  • 513 Answers
SOURCE: Sony Handycam DCR-PC1E
I'm not from the UK so can't help you find a lab. but regarding your problem - The fact that it works well without a tape tells us that the load motor and possibly even the capstan motor and associated mechanisms are working. It doesn't tell us much about anything else though. Could be that the head drum is not spinning - This can be the result of a siezed drum motor, or power supply fault(if seized it will draw excess current, thus giving a battery warning indication). A faulty, or possibly even a correcly working dew sensor - This will allow the heads to spin, but prevent the tape from actually lacing up. This is a 'hard' one really, because if the dew sensor is faulty you will get this problem, but you will get the same problem when the sensor is working and actually doing its job in that it has really detected moisture. There are many other possible causes too. The first thing to look for is to see if the heads are spinning - or at least see if they *try* to spin, because unless they *are* spinning the tape will never load. Also, the heads *shouldn't* be spinning with no tape inserted - if they are then this suggests that the dew sensor has been activated (the heads are made to spin under this condition in an attempt to dry things out). If this gives no clues, the next step would probably be to dismantle the thing and attempt to load a tape by hand (looking for signs of jamming mechanism, etc. Anything more serious than this is one for the workshop. Platano guatemalteco? Good luck!
Posted on May 29, 2006
  • 35 Answers
SOURCE: cant get my sony handycam dcr-pc55e tape on my pc .
Hi, I was wondering if you are using the AC Adaptor while downloading video? When you are not operating the camera, it will shut off automatically after approximately 5 minutes. This is to save the battery. It can be changed in the Standard Set menu: The item is called A.Shut Off. This can be changed to Never. Otherwise, I would use the AC cable if you aren't already.
Posted on Jul 01, 2007
  • 281 Answers
SOURCE: sony Model DCR-TRV350 Tape stuck in camera.
take out the battery, put it back, turn it on and you take the tape out of the camera. hope this helped you. have a great day.
Posted on Mar 03, 2008
  • 905 Answers
SOURCE: Get video off Sony Handycam DCR-TRV118 Hi8 to PC or Mac
You can use a Digital8 Camcorder to directly play 8mm and Hi8 analog tapes and output them to your computer via firewire Capturing 8mm/Hi8 with a Digital8 Camcorder
Posted on Nov 02, 2008
SOURCE: Unable to use firewire Sony handycam DCR-HC 54E (mini DV)
I have a Sony Camcorder DCR-HC62E with same problem and found a workaround. The iLink seems not to be enabled in the camcorder except for only one of the working modes: setting PLAY/EDIT and then choosing STREAM. Once you get to this condition with the provided USB cable properly plugged at both ends, Windows recognizes a new device and asks for a driver, so you insert the provided Handicam Application Software disk and make Windows install it (I got a Windows message saying the driver is not safe but went on anyway).
Of course that in such a mode the Sony application "Import from Handycam (tape)" cannot and does not work, but using Microsoft Movie Maker and selecting File->Capture Video the camcorder is shown. Select it by clicking its icon and Next. On next screen Captured Video File define the required info and press Next. On next screen Video Setting select Best Quality.. and Next. On Captured Video screen be sure to have checked Create clips when wizzard finishes and proceed manually as follows: go to the beginning of the tape (or of the part you want to download) using the rewind/forward/play/stop controls in the camera. Once ready press Start Capture in Movie Maker and simultaneously Play in the camera, the filemed movie will show in the preview as it is played. When you're done stop camera play and press Stop Capture.
Posted on Mar 19, 2009
How to copy 8mm tape using DCR-TRV350 to pc.
You will need an analogue to digital converter box. You connect the camera to the converter box with analogue cables and connect the A/D box to the PC with a firewire cable.
Note: Many mini DV cameras with analogue inputs can act as an A/D Converter box.
Jun 05, 2011 | Sony Handycam DCR-TRV350 Digital Camcorder
I have a mini DV SONY DCR-PC9E PAL camcorder and i need to copy my tapes on my WINDOWS 7 Ultimate 32bit. Don't Have the Driver, and my computer is not reading the USB cable connected from the Camera to the...
I believe this camera has a firewire/iLink connector.
Using a firewire cable will allow you to not only transfer videos, but will also let popular video editing software control your camera for ease of use!
As for the driver, your camera is specific to latin america.
You might try to download this program which is a licensed sony product, but will be in spanish. It may have drivers built in, which will allow your pc to properly recognize your device in other programs.
Feb 23, 2011 | Sony Handycam DCR-PC9E Mini DV Digital...
How can I copy a home shot movie using my Sony DCR-TRV900E to my PC? Is it possibe to copy it directly from the camera I will I need to buy something else as an intemediate step?
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Sony has a tutorial on how to do transfer to computer (Mac or PC) at THIS LINK
Nov 19, 2010 | Sony Handycam DCR-TRV900E Mini DV Digital...
How to trasnfer videos on tape for DCR-TRV33 to file on a pc?
Since you've got a MiniDV camcorder,you only need firewire(IEEE1394) card&cable to establish connection to your PC.Those card&cable should be available at any computer hardware store in the world.
Sep 03, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
I have replaced a Windows XP PC with a new PC running Windows 7 Home Premium and I have not been able to connect my DCR-HC26 Sony Handycam digital tape camera to the new PC. I'm using an I-link (firewire)...
Mostly with these cameras you do not need driver (unless you use a USB cable) but like me you have firewire okay? so you should unplug your camera, turn your PC off for a min or two, plug camera in THEN yes THEN put your PC on, and the Win 7 will see your camera and loads setting it needs auto ok.
May 29, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
I want to copy videos from sony dcr-hc21e to my PC. Explain how?
You can download the user manual and drivers from the below link and get started.
It is very easy to download and understand the usage, just follow the instruction given in the manual and you will be expert in using your camcorder.
Drivers
http://www.nodevice.com/driver/DCR-HC21E/get39780.html
User Manual
http://www.sony.co.in/support/product/dcr-hc21e/modelfirst
Sep 25, 2009 | Sony DCR-HC21E Mini DV Digital Camcorder
Yeah ! Your problem is very simple. u can solve it on your own.
If you dont put the tape the comparment closes well and as soon as you pot the tape the compartment does not close , Right ?
The solution is there within ur hands itself.
If you want the compartment to be closed, then simply dont put the tape inside. let it be outside itself. U see, its so easy !
Aug 08, 2008 | Sony Handycam DCR-HC90 Mini DV Digital...
Sony DCR PC110e camcorder
My problem with the DCR PC110E Sony camcorder is being unable to download my videos from tape to the PC or laptop through the firewire connector. Have you ever had this problem?
Feb 09, 2008 | Sony Handycam DCR-PC110 Mini DV Digital...
Video Cameras Logo
89 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
