How do I replace the door switch button?
How do I replace the door switch button on a Maytag Neptune MAH8700AWW? My wife broke it off and now the unit can't tell the door is closed.
  • 850 Answers
Unscew & raise the top panel to gain access to the switch
easy fix!
Posted on Jul 21, 2009
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Washing Machines
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
Oct 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washer model #MAH4000AWW. Just happened! Water fills then nothing. Wife says it "seems" like it wants to do something but doesn't
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune modle mah8700aww the door won't unlock
Getting rid of the Maytag Neptune is the only solution!
Feb 14, 2010 | Maytag Washing Machines
Our maytag neptune mah8700aww front loader will not drain and unlock the door. what do i do.
The drain pump os obviously either blocked or gone. Lie the drain hose on the ground to drain by gravity. Then have a look at the pump. This may need to be taken out as I'm not sure if there is a pump filter on this particular model. The door is designed to not open with water in the drum.
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Jun 14, 2008 | Maytag MAH8700A Front Load Washer
My maytag neptune washer #mah8700aww,display "lo" what is?
maytag neptune washer model # mah8700aww. there is no power on the display. checked power to outlet,
Apr 29, 2008 | Maytag Washing Machines
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
