Question about Furniture
Parts and repairs and how to do it.
My Ekornes recliner began losing pieces of black plastic from both sides from the mechanism that permits reclining. I was curved with ridges. At this point the plastic has completely broken off and fallen out of its position. It makes a noise when one sits in the chair.
  • 19 Answers
SOURCE: camry power driver seat motor won't return from recline position
it has three septet motors with gears
if one is bad you will replace it
Posted on Feb 24, 2009
  • 37 Answers
SOURCE: Camaro - broken reclining seat mechanism
the recliner is the outside seat hinge and has 4 bolts holding it to the seat cushion and seat back.The seat covers need to be pulled back to gain access to bolts.Can be done with seat in the vehicle.
Posted on May 27, 2009
SOURCE: cosco juvenile stroller -- how do i change the
I have the same stroller. Look behind the seat back, where you should find a ring and a squeeze clip similar to those used to close bags of chips. Hold the ring, squeeze the clip, and push the seat back towards the front of the stroller.
Posted on Jun 04, 2009
  • 31 Answers
SOURCE: Invacare power chair model #1089384;
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Posted on Apr 07, 2011
  • 1622 Answers
The best thing to do in this situation is to call the vendor and have them repair it under warranty. There should be no charge for this service since the chair is brand new.
There are some checks you can make to avoid a service call. You have checked the batteries and hopefully the chair is plugged into the wall outlet. It is possible that something got disconnected under the chair. To check this you need to flip the chair over on its side or on its back since the leg rest scissor mechanism is extended. Look for any plugs that have come apart at their connections. Check for a pinched or binding scissor mechanism or tilt frame parts.
You should not attempt this at all if you cannot safely move a large piece of furniture. Perhaps a friend or relative may be able to help.
Insist that the vendor honor their warranty commitment ASAP. If you paid with a credit card, you should contact your credit card company to put the amount in dispute if the vendor is unresponsive. Hope this helps.
And you can troubleshoot with the below instructions if it with also help
things you'll need:
* Pride chair Owner's Manual
* Screwdriver
* Wrench
* Pliers
Look at the chair's electrical plug, as the chair most likely became unplugged or the plug is not fully connected to the outlet. If this is the case, securely reconnect the plug.
Check the chair's connections. The electrical connections under the chair could be loose or connection cables could be pinched or bent. Tighten loose electrical connections with a small screwdriver and straighten bent or pinched cables.
Check the chair's transformer, motor and relay box under the chair as a malfunction in any of these could cause the chair to stop working completely. The hand control used by the operator to change the chair's position may also be malfunctioning.
Test the chair's wood frame, bolts and lift frame. Loose wood frames or bolts, overly tight bolts or the lift frame rubbing against the wood frame will all cause the chair to squeal.
Lay the chair on its side and check the wood frame and t-bracket. If the wood frame is rubbing against the lift frame or the t-bracket is cracking, you could hear popping noise. The t-bracket is the metal frame on the underside of the lift chair.
Check the dual motor timing if the chair will not recline all the way. The motors' timing could be off which would stop the chair from completely reclining. Put the chair on its side and remove the motor and plug it in. Use the hand control to turn the motor on and let it run until it stops on its own. Screw the push tube, located to the right of the drive tube where you just removed the motor, until you feel it bottoming out. Turn the push tube back two turns and grab the push tube. Turn the unit on with the hand control and allow the push tube to move away from the metal casing. Push the pin at the back of the push tube and reinstall the motor. This should re-time the motor.
Look at the wood frame, seat foam, leveling legs, motors and bolts if the chair is crooked. The wood frame could be twisted, the seat foam may be broken or misshapen, the leveling leg may need adjustment, the motor could be timed incorrectly or the bolts could be loose. If all looks in order, make sure the ground under the chair is level.
Unplug the chair before you begin fixing the chair.
Restore power to an inoperable lift chair. Ensure the circuit breaker box is connected to the electrical outlet. Make sure the external transformer is plugged directly into an electrical outlet.
Fix a Pride lift chair that only operates in one direction. Use a cotton swab to remove dust and debris from the toggle switch on the hand control. Flip the toggle switch back and forth to loosen any remaining debris which may be causing an obstruction.
Fix inoperable heat and massage features. Check the LED lights on the hand controls; the LED display is not lit, hand-tighten the connection between the hand control and the lift chair. Make sure the the heat and massage units are properly connected to the back of the lift chair.
Posted on May 02, 2011
Our chairs will not swivel properly. What can we do?
Purchasing a new high-quality Swivel recliner can be a better option for the problem.
You can get whole guideline and information about various different high quality swivel and non swivel recliners from Loveseat Recliner.
The best collection of trending swivel recliners are:
Jan 24, 2016 | Ekornes Stressless Recliner Chair Personal...
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
I have a Maytag microwave UMV1152cas. I recently replaced the magnetron because it was not cooking food. I began putting it back together and have it all back together except for a plastic piece.
Maybe this will help. Here is a link to an explode view of your Microwave. There are other exploded views on the right-hand side of the page.
Jul 22, 2015 | Maytag Microwave Ovens
Home Meridian Comfort Lift Chair - lift mechanism is sloppy in partially reclined positions
Bolts commonly loosen up on these. You may be able to tighten them. I had to turn the chair over, pull out some of the staples that hold the material on and find the nut that went on the inside, then I was able to tighten the bolt again and staple the material back in place. I also had to make a new plastic cross bar for the scissor assembly by using a half inch PVC pipe and two flat plugs and two couplings, I then drilled a hole in the center for the screws to go in. Painted the newly made one with black plastic paint from Lowes and it's stronger now then before. If you want parts here is Home Meridian's contact..........
Jan 24, 2014 | Home Meridian Comfort Lift Recliner
We have a Krups FBC4 1600 Watts Toaster Oven. The door hinge seems to have disconnected from some kind of spring mechanism within the left wall, is there any way to take apart/repair it or have it...
Here is a Krups website address that helps you locate service by state or contact the Krups company.
Apr 08, 2011 | Krups FBC4 1600 Watts Toaster Oven with...
How do i replace the reclining lever for a 2008 dodge avenger
The mechanism is probably held in with a bolt and spring, so you'll
have to remove the plastic side cover around the bottom of the seat,
to gain access. Once the cover is off, you will just need to remove and
replace the bad parts.
Mar 29, 2010 | 2008 Dodge Avenger
Front seat passenger side backrest will not recline
More than Likely Stripped out. This is a Dealer only Repair. You could get the Parts from the Parts Counter at the Dealership and repair this yourself But, It is not Easy!
Jan 22, 2009 | 2001 Oldsmobile Alero
Furniture Logo
143 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
